Keyfobs question
Keyfobs question
I’m trying to understand if this is normal with the keyfobs.
Car is locked, driver one enters the car, it is being recognized as driver one, everything adjusts correctly.
Now driver one leave the car and doesn’t lock the doors, now driver two enters the car, because the door wasn’t locked by driver one after exiting the car the car doesn’t recognize the keyfob 2 as driver two.
If driver one locks the door after leaving everything is ok.
This is typical in household where car is parked in garage and not locked.
Simple procedure to make sure settings are correct "first time everytime":
Touch door handle first to lock, then inside door handle to unlock. I do this when I know wife has used car (which is rare).
ehhh.... key fob should be where they are, in your pocket.... it shouldn't be hard to touch the nipple on the door handle to lock it.... when you have your hands full, use your nose, elbow, forehead, ear, toes, to lock it.... more convenient than reaching into the pocket to push the button
..... and if you are really worry about driver settings, set both key fob to have the same setting so it won't bother you or make a difference which key fob setting you need
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
