Idea: KB2 AT6 gearbox to KB1?
9th Gear
Just a though.. If one has failing tranny in KB1, could it be possible to fit 2011 upgraded 6-speed tranny to 2005-2008 J35 engine in RL instead of the J37? Would anyone has knowledge of the ECU compability? Does RL have separate gearbox ECU in addition to engine ECU?
Will the tranny fit physically "bolt on"? Would a Acura ZDX unit fit?
It'll bolt up no problem.
I've never dabbled with the ECU pinouts for the KB2 but the ECUs are most definitely different.
At minimum you'll need the KB2 engine harness, ecu & ecu sub harness. Don't think it's too complicated but at the same time it won't be a walk in the park either
