How to shut off NAV?
When using the NAV system to go HOME, there comes a time when you know where you're at and how to get home from there. How do you turn off the NAV system, without having to shut the car off and restarting?
Inquiring minds want to know...
Press "Menu" and the select "Cancel Current Route."
The following 2 users liked this post by BDoggPrelude:
05RL in NH (07-01-2014),
oo7spy (07-01-2014)
You can reduce the screen brightness to off. Use the knob ring.
The following 2 users liked this post by HEAVY_RL:
05RL in NH (07-02-2014),
oo7spy (07-01-2014)
That's probably what I was thinking about.
HEAVY_RL (07-02-2014)
Torch & Pitchfork Posse
The only means I know to disable the NAVI is not to accept the 'OK' on the boot up nag screen. Then the screen remains blank.
If you enable the NAVI on start up you can always select an alternative view screen instead of the map once you are done using the NAVI. The AUDIO screen or TRIP COMPUTER, or any of the embedded features aside from the map.
As mentioned above, you can CANCEL a current NAVI program, to discontinue voice prompts (assuming you have your settings for voice prompting) and if not viewing the map is your issue, select an alternative feature. If your ultimate desire is to blank the NAVI screen, there is no method I am aware of once the NAVI is initialized on start up.
It's good to see the gang back together. :gheyhug:
oo7spy (07-03-2014)
TampaRLX-SH (07-03-2014)
