How to replace rear door molding
Old 12-10-2009, 02:40 AM
sleepinxlionhart's Avatar
As some of you may have known, there was a little incident with the RL getting scrapped. Now, the incident took off paint off the rear door molding:
The two white dots right under the chrome strip.
I'm planning on replacing it because it is about the same price as if I were to get it repainted. Now, the question is, if I replace it, is it a simple DIY? Would I have to basically take apart the whole door panel to get to the clips (I assume) that hold it in, or is it possible to remove it from the outside? Does anyone know, or have a service manual for it? Thanks.
Old 12-10-2009, 06:52 AM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
GARAGE Sticky > SERVICE MANUAL > EXTERIOR TRIM pdf
You can see the diagrams there. But here is the text:
DOOR MOLDING REPLACEMENT
Special Tools Required
KTC trim tool set SOJATP2014 *
* Available through the American Honda Tool and Equipment Program; call 888-424-6857
1. Remove these items:
 Front door panel (see FRONT DOOR PANEL REMOVAL/INSTALLATION ) and plastic
cover (see step 3 under FRONT DOOR OUTER HANDLE REPLACEMENT )
 Rear door panel (see FRONT DOOR WEATHERSTRIP REPLACEMENT ) and plastic
cover (see step 2 under REAR DOOR GLASS, QUARTER GLASS, AND REGULATOR
REPLACEMENT )
2. Release the clips, and gently pry the front door molding (A) or rear door molding (B) away from the
door while separating the adhesive tape (C, D, E).
Adhesive tape (C, D, E): Thickness 1.2 mm (0.047 in.)
Fig. 19: Identifying Door Molding
NOTE:  Use the appropriate tool from the KTC trim tool set to avoid damage
when prying components.
 Be careful not to pry too far or you may bend the molding.
 Put on gloves to protect your hands.
2007 Acura RL
2005-08 ACCESSORIES AND EQUIPMENT Exterior Trim - RL
Courtesy of AMERICAN HONDA MOTOR CO., INC.
3. Install the moldings in the reverse order of removal.
Old 12-10-2009, 07:07 AM
2011 ZCP E92 M3!!
dave_ramkumar's Avatar
REPLACEMENT )
2007 Acura RL
hey this should work for my tl too right? i been think to change one cuz it has a scartch on it but i didnt wanna mess up the paint while remvoing the old one
Old 12-10-2009, 01:12 PM
Thanks Tampa!
Ugh....seems like the door has to be taken apart :/.....I think I might just get it repainted.
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
wilztlxs
12-01-2015 09:16 AM
obert
10-29-2015 10:37 PM
09-04-2015 08:03 AM
Quick Reply: How to replace rear door molding
