How do I disable DRL?
I typically don't care about the DRLs being on but when I go to a star party (stargazing) I'd like to be able to disable them so I don't affect the night vision of the other folks. I noticed this morning when I got in the car to check on the navtraffic icons that there was a 'DRL' 'drl off' message in the info screen. So I checked the manual. It's not very clear how to disable DRL. Does anyone have a clear description on how to do it?
It's important that the DRLs don't come on when I turn of the regular headlights when I pull into the parkinglot.
Thanks!
Thanks!
I have no idea... I had noticed it a few days ago when I parked on a steep hill and I used the parking brake. I wasn't sure why it did that - but the same thing about 45 minutes ago when I parked on the same hill. Not sure why though... have you looked in the manual?
Yes, I wrote so in the original message :-)
It's more explicit about how to turn DRL back on rather than make it stay off. Right now I think that once you've turned the headlights on DRL will come on once you turn your headlights off. We'll see. Worst case I make some blinds that I can stick on the hood with magnets for the last 100 yards. Oh wait! Aluminum hood!
It's more explicit about how to turn DRL back on rather than make it stay off. Right now I think that once you've turned the headlights on DRL will come on once you turn your headlights off. We'll see. Worst case I make some blinds that I can stick on the hood with magnets for the last 100 yards. Oh wait! Aluminum hood!![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
If you set your lights to the "auto" setting where they come on and off depending on ambient lighting, day time running lights don't come on.
When in the auto position, you never need to turn lights on or off...
Well the problem is that I need to be able to drive in the dark without DRLs or headlights on. Once the switch is in 'auto' the DRLs won't be on during the day but I don't care about that. I don't want them to come on once I turn off the lights while driving in the dark. Covering them up is probably the only solution.
Originally Posted by Rich in NC
I'm not sure of that. My light switch is always in the auto position and the DRLs are on? DRLs are designed to do just that. Be daytime running lights. Not sure why would the auto position would defeat that?
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Every time I've changed the oil and I have lifted the front of the car to do so, the DRLs go off for a while afterwards - they seem to come on again the second time I turn the car on
Originally Posted by 1HOT NSX
For a moment I thought WOW, someone figured out how to keep the DRLs off during the day - I have a thing against them, but no such luck
I tried to pull the fuse off and they went off but I got a big warning on the info panel alerting me of the problem.
I would love to figure out a way to turn them off without getting the warning on the instrument panel - does anyone know how to do it?
I guess to each his own. I think the DRLs are a great safety feature. Coming out of the shadows on a twisting mountain road are a great example. Or even someone just pulling out of a shaded intersection.
I wish Acura, like Mercedes, would give you a choice of having them on - for you, and a choice to turn them off if I wish to - for me.
It would be nice if there was an option to turn it of. I don't like it when cars do too much of the thinking. Like turning on the AC when wanting to defog the windshield. I turn on my headlights when the viz is even the slightest bit degraded. Most people won't even turn them on when they have a low sun in their backs. *Clueless* to the fact that they just became invisible. All they worry about is how well they can see. Not whether other people can see them. One of my pet peeves.
Well I know why it's there and I agree that it helps
But it's not always needed. What I actually meant to write was when I turn on recirc in the S4 it turns on the AC right away. Thankfully it has an 'econ' button that disables the AC pump but keeps the rest automatic. Unless it gets really hot I typically drive without AC. In the RL I've disabled the AC as well but I'm not sure if it still adjusts fan speed based on external temps and desired temps. I miss that 'econ' button.
Ok, it turns out if you pull fuse #3 from the driver's side fuse box the DRLs are disabled. Of course the RL is smart and detects there's a problem and nags you about it. I may install a switch to disable DRL without pulling the fuse, not sure yet. Anyway, this isn't a great permanent solution but if the occasion calls for it (star party in my case) it's completely acceptable.
Does anyone else have any ideas on how to do this?
a) yes a switch would still cause the RL to detect it. There's obviously no difference between the two methods as far as the RL is concerned.
b) having a switch is tons more convenient than pulling a fuse. I can do it while driving. Pulling a fuse means stopping the car and getting on your knees with pliers or a puller to remove the fuse.
c) a 'real' solution is going to be hard as you have to fake a current through the bulbs when this is none. Someone with more incentive will have to come up with that one. Once I have the switch I'm set.
Just figure out the current draw of the bulbs and replace them with resistors that matche the current draw. They would be some pretty hefty resistors but that would do it. You could also paint the bulbs black with some high temp paint that would cut the light way down,
But for the life of me I can't figure out why you would want to turn off such a valuable safety feature. There is all kinds of times when it helps to let people know that you are on the road way before they would see you with the lights off.
DRL uses the high beam bulbs. Can't paint those black nor replace them with a resistor. If you'd like to know why I want to disable DRL at times simply read my original message. When I attend star parties (astronomy events) I don't want to ruin the night vision of my friends. So with my solution (it's not built yet) I can turn of DRL before I pull into the parking lot and turn it back on when I leave.
While driving? I hadn't considered that but it seems a bit error prone, no?
Put your car on a slight grade and try one click. If it continues to roll you have no actual brake engagement.
It would be acceptable for me if it meant I could drive on/off a parking lot without my DRLs. I'm going very very slowly in that case anyway. I'll have to give it a try.
Originally Posted by scottj
I'm certainly no expert here, but I still think there's some risk. There can actually be a fair amount of brake engagement and the car can still roll. This seems like a great way to really smoke your brakes if you're not quite careful. Trading no DRL for warped rotors seems like a bad deal to me.
Also rotors rarely, if ever, truly warp:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Finally the requested solution was for somebody rolling up on an astronomy event. Not a cross country tour.
I also believe that if the car rolls (easily) you have no brake engagement. On the subject of warped rotors: the term describes the deposit of brake pad material on the disc produced by (among many other variables) a sudden increase on brake pad/rotor temperature due to sudden and heavy braking. Even if the parking brake is lightly engaged with one click it would not produce "warped" rotors, it would just wear the pad material until there was no longer contact at that setting.
Actually, this may be the way to go to "fix" the "problem" without too much trouble. Wouldn't the parking brake warning light come on at this setting? If so, this would be no better than just pulling the fuse and living with the DRL warning light.
Actually it would be a little better as you would have the DRLs back immediately for regular driving which is the situation, I beleive, Nocturnal was describing.
It ain't mine.
I am currently working on this right now,this vehicle has a drl module under the dash that controls them.So far through the wiring diagrams I believe the white wire from the module goes to the high beam circuit.I am going to try and cut this wire and install a led light in line and tuck them under the hood somewhere.I will post with my findings as soon as I get some time to start cutting.
unofficial HONDA rep
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Has anyone tried this recently? Specifically post 7
https://acurazine.com/forums/2g-rl-2005-2012-76/share-any-secret-tech-adjustment-tweeks-our-rl-acura-techs-tell-497497/
It ain't mine.
https://acurazine.com/forums/showthread.php?t=497497
It ain't mine.
I have just attempted to do the mod per the recommended posts.And as soon as I started the car I got the check drl system , so I believe that this way does not work either.
