Help Running Wires.
Take off the dead pedal. There is supposedly a hole large enough for an amp wire there.
ChocBoyWonder (11-23-2014)
I tried feeling behind the dead pedal and taking off the wheel and examining under the hood to see if I could find a place optimal to get the wire through but I found nothing.
Do you remember reading about the dead pedal in a thread or know anyone I may be able to ask? I'm going to look at running it from the glove thorugh the side and under the pillar which would bring it right through the corner underneath the windshield on the passenger side.
Any thoughts?
Any thoughts?
ChocBoyWonder (12-10-2014)
Here is how I ran mine. I chose to drill Ito the firewall, and my hole came out just below the brake booster. This may give you some perspective about where to expect the wire.
https://acurazine.com/forums/audio-b...emoval-813630/
oo7spy (12-10-2014)
I think it's drilled thru. I had my headlight retrofitted and that's how he wired it. It's too cold to take anything off but I'll take a look if it warms up lol
Are you running wire for amp battery? I ran a 4 gauge wire from the battery inside the fender and through the wall (through the rubber wire thingy for the door wires). If you have a look at the link below, you'll know what I mean..lol. It is the picture that shows about 3" of blue wire when you open the door. If it was a black wire, you probably would never notice it.
https://acurazine.com/forums/audio-b...amp-rl-810416/
SinCityTLX
10-07-2015 01:24 PM
