Help identifying buzzing sound from dash (video)
I have this buzzing sound coming from behind the lower drivers side dash between the steering wheel and the center console. It almost sounds like there's a fan going bad behind that small vent and I can sort of feel air being pulled through when I place my hand over it.
I was thinking it might be part of the automatic climate control where it would suck air through that vent and blow it over a temperature sensor. When I turn the climate control off, the noise continues. It also get louder when the steering wheel is turned.
Below is a video. When I place my hand over the vent, the sound stops, then when I remove it, the buzzing sound returns. Any idea what it might be? I have some time this weekend and might pull the dash apart to investigate.
After reading through the owners manual, it turns out that it is a temperature sensor for the climate control. It's easy to remove. Just slide a plastic spudger behind the left or right side of the bezel and it pops right out.
The red and black wires aren't part of it. I soldered those on so that I could bench test it and figure out a way to shim the fan. It's fixed temporarily, but I'm still going to replace it right away with a new part.
![Name: tempSensorAssembly_zps2533887d.jpg
Size: 197.7 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/75197d1501528237-help-identifying-buzzing-sound-dash-video-tempsensorassembly_zps2533887d.jpg)
![Name: fanAssemblyFront_zpsf8faaa01.jpg
Size: 215.9 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/75198d1501528237-help-identifying-buzzing-sound-dash-video-fanassemblyfront_zpsf8faaa01.jpg)
![Name: fanAssemblyBack_zpsdbce1e51.jpg
Size: 230.4 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/75199d1501528237-help-identifying-buzzing-sound-dash-video-fanassemblyback_zpsdbce1e51.jpg)
![Name: fanBezelSide_zps9b83ffb8.jpg
Size: 213.3 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/75200d1501528237-help-identifying-buzzing-sound-dash-video-fanbezelside_zps9b83ffb8.jpg)
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
