headlight question
headlight question
It appears as though my passenger headlight might be misaligned, looks like it might be pointed more towards the ground than the driver headlight. I've noticed for a while now in reflections that the passenger side isn't as bright as the driver side. Looking at them both head on at eye level it's obvious the driver side is brighter and when you look at the glare on the lens you can see that the glare is more center and the passenger side glare is lower on the lens. That being said, is this common for the headlight to become misaligned?
I can clearly tell at night that the passenger side doesn't illuminate the road as much as the driver side.
when did you get the RL?
have you done any work on the RL?
I really think the bulb isnt seated correctly...but without physically looking at the car, I cant be sure....
I dont know what yyear your car is, but something tells me that some one replaced the bulb and didnt seat it correctly...
there are notches in the bulbs base, it has to line up in the headlight housing, or else you get what you're getting
^there's a chance the dealership didnt install the bulb correctly and the previous owner has been driving like that for 3 years.
BUT, since I cant PHYSICALLY check, I cant be sure.
if you have tiny hands, you can reach through the wheel well and feel around for the bulb to see if it's seated correctly. you might have to pull the bulb out and re-install it.
if hand cannot reach through wheel well, front bumper needs to be dropped so that you can gain access behind headlight housing
Can you post a picture of a wall shot from 25 feet distance showing the low beams. Thanks.
oo7spy (01-08-2016)
The following 4 users liked this post by Carbon Legend:
1st, take a picture at night in front of a wall on level ground. Not too close, not too far. Like Comfy said.
2nd, the passenger bulb can be accessed through the engine bay if the washer reservoir is removed. Shouldn't need the wheel well or bumper on that one.
3rd, the dealer blew smoke up your ass. Probably doesn't smell any better though.
4th, almost every car has a verticals adjustment screw on top of the assembly. Not positive about the RL however.
The following 2 users liked this post by oo7spy:
Comfy (01-12-2016),
justnspace (01-09-2016)
oo7spy (01-09-2016)
The following 3 users liked this post by justnspace:
Wondering if the OP has JDM headlights with RHD cutoff...
driver's side bulb looks like it has a severe hotspot... i think the bulb was installed incorrectly..
also a flat wall would help too
Based on that picture, something is definitely wrong. My RL's lights are very evenly spread, with the normal slight step-down on the driver's side to avoid blinding oncoming traffic.
get a better picture on a FLAT wall so we can help you.
Or just take it back to the dealer.
That was not level ground in front of a wall.
That appears to be a slope in front of a small incline of grass.
No, the lights are pointing toward the ground. Either the ground is raised, or your headlights are both seriously fucked.
Here is an example of what we are looking for. Notice:
- Even distribution of light.
- Cutoff is level from the headlights and below the eyes of oncoming driver's.
- Step up from driver's side to passenger's side.
Comfy (01-12-2016)
Yes, exactly what we are looking for. That's a super cool and clean light. Is it retrofitted?
@ OP, if you can't find a level ground and flat vertical wall, go to the nearest supermarket / shopping mall at nightfall and take a picture from the parking area against the shop....
I dunno, but I can't seem to see the picture original posted by OP. Is it deleted or in some format unreadable by my computer?
I can still see the pic, Comfy. My picture was a retrofit. Going back to the OP's pic, I don't even see the passenger beam. The lights stops way too early on the right for it to be from the passenger projector.
Oh, it's a bush.
That's cool. Glad everything is fixed well.
A4orce84
01-10-2016 11:20 AM
