Front lower ball joint
Hi, I just bought a used 2005 RL 156000 KM. After an inspection from my mecanician friend, we saw that both front lower ball joint are very loose and are needed to be change. But, when I look for the part number on acuraoemparts.com, it seems like I can't buy only the ball joint and that I need to buy the whole arm which is 400$ USD each. That's a very high cost... Do you know where I could buy front lower ball joint? Everywhere I'm looking at, they only sell the upper ball joint... Anybody here had to change his front lower ball joint?
Thank you in advance
P.S.: Sorry if my english isn't perfect, I'm from Québec, Canada, so I'm a french speaker.
I'm almost 100% sure the only way to replace the lower ball joint is by replacing the entire control arm. I don't know of anywhere that supplies the lower ball joint separate from the lower arm. Sorry!
You do have to replace the whole control arm. Our suspension bits are made of aluminum so the ball joints can't be pressed in and out like you can with steel/iron control arms. On the bright side it makes the installation go a lot quicker and the you get new bushings too.
Hmm, looks like an aftermarket lower control arm (made by Dorman for around $200) is available for the 2009-12 RL but isn't listed for the 2005-08. There was a mid cycle refresh to the J37 engine and beak - but was the suspension changed? Anyone know if the LCA will fit on the pre-refresh RL?
Ratheruneeq - the issue is endemic to all cars with aluminum suspension bits.
The aftermarket lower arms for 05-08 are/were available as I changed both of ours a few months back.
Cost about $220(for the pair) for Beck/Arnley.
I believe most are listed as correct fitment for all years, I know the ones I used are.
Thank you for posting this as this is a topic I was going to research out. Where can I get the Beck Arnley number and supplier? $220 beats out $382 from Acura Parts warehouse if it is the same part.
In my humble opinion paying $162 more for the reassurance of OEM quality and reassurance isnt all that bad. I could see if it was $500 but you can never go wrong with OEM.
YOu have to remember that this is times 2 so the cost spread is even more. I agree with you on the OEM part, just looking for a better price for the same part.
I agree that there is a perceived benefit from having OEM parts but often it is nothing more real than perceived.
The ones I fitted look just as good as the OEM and I have a lot of experience in suspension parts.
BECK/ARNLEY 1027677
BECK/ARNLEY 1027676
I got mine from Rockauto but I believe they can be had elsewhere.
$220 vs $790... no brainer imo.
BECK/ARNLEY 1027677
BECK/ARNLEY 1027676
oo7spy (08-22-2015)
BECK/ARNLEY 1027677
BECK/ARNLEY 1027676
BECK/ARNLEY 1027677
BECK/ARNLEY 1027676
Oh RockAuto is the place to go imo
BTW I stated 'often', sometimes it's not but not as often as some would have you believe. Honda don't make all their own parts you know.
And a couple of hundred is a big deal to some people, in this case $600 is probably a big deal to most.
Just trying to help people out here, if you insist on only buying OEM parts then fine, you pays yer money, you takes yer choice.
Exactly as I stated, I trust you have more than my 30 years of automotive work experience and have fitted more than the hundreds (if not thousands) of suspension parts that I have.
Beck arnley i hear isnt all that bad. I know Moogs premium aftermarket lines are as good or exceed oem quality. Ill personally never buy aftermarket axles ever again.
My mechanic once swore buy getting me these NEW axles for my g2 legend. They didnt make to my next oil change and he was swore they were good as he used them on plenty of vehicles.... yet and still it has been well documented in the legend community that theres really much of any aftermarket axles that hold up well in the legends....
Im sure youve done plenty of work and are plenty experienced.
But to be honest, when you buy a used or new 55k luxury car one needs to factor in the expenses of maintaining it properly otherwise go buy an eco less expensive vehicle.
JDMCRX (08-24-2015)
I always buy aftermarket axles/driveshafts, I use them on daily drivers, race cars and all those in between, from cheapo Civics to Aston Martins.
The amount of failures due to poor quality is extremely small.
Maybe you got unlucky but that's no real reason to never use something ever again.
All these parts do have warranties as well.
If you buy new after market you might be getting something from China. A local repair shop said to buy rebuilt originals as they will last longer. I just don't want to be half way across Texas in the middle of no where when the axle blows out. The local Honda shop said they buy Napa and never had an issue. I might opt for the Beck-Arnleys and see how they hold up. Some parts are from one source, just a different label and box it comes inas it the case of the power belt tensioner. It was from Napa and side by side it was identical to the original part in every respect. A whole lot cheaper too!
marcelft
07-10-2018 06:17 PM
