Fogged headlights
Fogged headlights
I could not find a thread on this, except some scattered posts about it being repaired under warranty.
I'm way out of warranty at this point. I was wondering if anybody knew anything more about fogged headlights? Is there a way I can clean up the lights and then reseal the existing ones? How much do new ones cost (probably a ton)?
No. My headlight has water condensation inside. Not sure how it got there, seeing as how we haven't had rain in a year. It probably happened when my car was being washed.
It's been there about 3 weeks now and doesn't seem to be able to evaporate.
O i c...
guessing a bad seal. You can do the oven treatment. to get the lens off then clean the lens really well. then instally some nissan Butyl rubber robe to seal up the headlight.
http://www.theretrofitsource.com/pro...roducts_id=792
Now any advice/instructions on removing the headlights? I'm guessing I will have to remove the front bumper as well.
Former Sponsor
Refresh
Here are some before and after pictures.
Details
2G RL headlights
Refinished inside passenger side lens
Complete front lens restoration
Disassemble and clean all internal parts on passenger side light.
Resealed headlights
BEFORE
AFTER
Details
2G RL headlights
Resealed headlights
BEFORE
AFTER
Wow - where do you live? I would pay you to do this for me!
Those lights in the pictures are mine. I sent my lights to JnC to get them fixed up and so far its been a great process. I am looking forward to getting them back and installed. I recently bought a second car so I was able to lay up the RL for the two or so weeks it will take (shipping to and from).
I would highly recommend JnC.
Hey Jnc. I need ur services asap!! Sent u a pm.
Former Sponsor
jose3031's headlights
Didnt feel like starting a new thread so here are a couple of pictures.
Details
05-06 RL headlights
Bronze bezel painted matte black
Silver DRL and low beam bezel painted hi gloss black
Turn signal diffuser garnish/strip painted hi gloss black
Smoked out parking light amber diffuser
TSX-R clear lenses with custom cut off shields
New Phillips 85122+ bulbs
Details
05-06 RL headlights
Former Sponsor
BTW, the RL headlights are a pain to work with, especially taking off all the bezels and all the pertinent fixtures. Just to give you an idea, there are a total of 27 freaking screws holding everything in place within each headlight.
The worst part is taking off the amber diffusers and the front clear turn signal diffuser and the garnish on top of it. Its pretty much impossible if you are impatient. lol
rather than send him a PM, why not just give us all a ballpark idea what this costs, should we ever decide to send you our headlights?? is this a $250 job or a $500 job, or more???
i like the fact that you can customize stuff by painting... I'd also love to see those fugly orange amber things changed to clear!
JnC (04-16-2012)
Former Sponsor
Job depends on what needs to be done.
Labor for just painting the internals is $175. I usually charge $150 for the 3G people but the RL headlights require at least a couple of hours just disassembling everything without damaging any of the parts.
Lens resurfacing ranges from $40~$60 depending on how bad they are, so that would alter from one set to another.
TSX-R clear lens swap with custom cut off shields is an additional $70, includes cost of lens.
Phillips bulbs are $90 for the pair.
Hope this helps .
Lights come with warranty against leakage, fogging etc. I have been doing lights for almost 10 years, 7 on AZ alone and I stand behind my work. For references my few threads in the 3G and 4G sections can be checked out.
The following 2 users liked this post by JnC:
Carbon Legend (05-05-2014),
EL19 (04-17-2012)
JnC has been 100% professional and communicative throughout this whole process. I hope the RL folks pick up on this and start using him for all their headlight mod needs. You could do it yourself and royally screw it up or give it to him and know it'd be done 100% to your liking.
Results talk.
BS walks.
Results talk.
BS walks.
This thread inspired me to try restoring headlights of a friend's 2000 BMW 3-series. I used one of those $25 kits. This IS a lot of work and required much more than a kit if you want it to look new like this guy does. However, about 30 minutes per side and they looked very good, not perfect, but very good. She was thrilled because they were so far gone she could not see and they had a yellow cake layer on them. I had to use 320 grit on them to grind off all the crud, then the 1000 and 3000 that came with it. But then, there is still a haze inside, and that's what I could not do. If the lights look new like they do in these pics, this service is worth it. Luckily my RL was probably garage kept because the headlights are clear. I like the custom paint, but I like the stock black chrome as well. I wonder how they would look with the car's exterior color? Well, not on this car...
Former Sponsor
RLCLAW's headlights
RLCLAW sent his modified headlights to be fixed recently.
Issues on arrival
- Bad seal
- Scratches on the outside of the lenses
- Scratches and damaged clear coat on the inside of the lenses
- Damaged silicone channel
- Water residue on the inside passenger side lens
Modifications
- Fixed silicone channel
- Removed/replaced all old sealant with black kioto sealant
- Resurfaced and clear coated both inside and outside of the lenses
- Replaced OEM ballast gaskets.
Before
After
Pictures to show clarity of the front lenses.
Issues on arrival
- Bad seal
Modifications
Before
After
3rd Gear
Guys im new hear so be gentle.In England we have the same issue on headlights on the 7th gen Accord.
A good cheap fix is to fix 50 gram silicon bags in the light unit job done.
Jnc does excellent work...he has done 2 sets of 3G headlights and a set of is250 headlights for me and I have no complaints...he puts a lot of effort into his work and stands by it
