fluid question
fluid question
wats up,
I am getting ready to do an oil change and I would like to change all the fluids and i was just wondering if I am leaving any out. tranny fluid, diff fluid, rad fluid, power steering, and washer fluid pops into mind..... am I leaving anything out
also I'm gonna take the car to a friend is honda trans fluid the same as acura trans fluid because i think i remember someone saying it was cheaper at the honda dealership
Yup, the differential uses standard Honda ATF.... Check online at several of the dealerships. I'm sure you can buy it cheaper on the 'net.
While your at it, change your oil filter. Check the cabin and air intake filters too (might as well while under the hood). Maybe lube the hinges and clean the engine too.
I would do the brake fluid before the radiator. You have Type 2 Coolant rated for 5 years. I would also do the brake fluid before the PS fluid.
Does anyone know if the ABS is a separate system like the old Legend?
