Failing ABS Module ABS/VSA/AFS/BRAKE
Hey all, I've been having the Christmas lights symptom on my 06 RL for a few weeks now (Check: ABS/VSA/AFS/SHAWD/BRAKE). I am at 240k + miles and it first started about 3 seconds after I hit a large bump on the highway. I checked for blown fuses, loose wires, loose grounds, checked the battery voltage and cranking amps, checked the terminals and I could not find anything out of the ordinary. My buddy hooked up his scanner and found the following codes:
126-4 (U0122) F-CAN malfunction (ECM)/Pcm- vsa control module unit
B1170 Gauge control module lost communication with the VSA/ABS modulator-control unit (VSA/ABS message)
41-2 Loss of communication with VSA control unit
Each of the codes were found in one of systems that are throwing the warning lights (ABS/SHAWD/AFS), it appears the ABS/VSA module is not communicating with the other systems. Hoping it was just a glitch/error, we tried to clear the codes, but were unable to. I unplugged the ABS module and cleaned the terminals, there was no rust found but I figured it wouldn't hurt, still no luck.
I am thinking the bump on the highway may have just been a coincidence or possibly the final straw on a failing ABS unit. Based on previous threads, it appears other members have had similar experiences with failing units. I ordered a used one from eBay and will be hoping for the best once I swap it out.
Does anyone have any insight or advice? Would like some re-assurance that I am taking the right approach.....
In case anybody cares or runs into the same problem... I swapped out the ABS module with a used one and flushed my brake fluid. Christmas lights went away at start up. Didn’t have to reprogram the new module or reset any codes.
TonyCD (12-03-2021)
gave me all sorts of cautions about replacing a modulator (bleeding, reprogramming etc). Glad to hear it was a simple swap and bleed as normal (ie all four corners).
just ordered a used one on ebay. Wish me luck.
I hate cars
07-31-2009 05:11 PM
