Damn Rattles
Damn Rattles
Anyone recommend a way to fix minor rattles coming from the plastic surrounding the shifter plate, and around the dashboard area?
It seems the plastic around the shiftgate hits to close to the top (ashtray side) of the shiftgate and is causing a creak when hitting rough pavement. Seems the shiftgate needs to be adjusted back slightly to fit in the center of the plastic cover. . . Anyone know if there's a way to adjust the shiftgate?
I also have a creaking noise coming from the gauges around the dashboard. Appears to be caused by the inside-top plastic piece screwed in place above the gauges, but I'm not certain.
I mainly notice the noise when driving over rough pavement and occasionally when hitting the brakes hard or excellorating quicker than normal. I hesitate bringing my car to the dealer for fear of worse problems arrising from their careless techs. I'm hoping others on this site can share their remedies with me. . .
The following link has some info on curing the shifter plate/center console rattle with felt pads.
https://acurazine.com/forums/showthr...ghlight=rattle
If the rattle is repeatable, setup an appointment with your dealer. I had a rattle in the glove box and took a ride with the tech. He fixed the rattle. I have the rear sunshade rattle and some mysterious rattle behind the NAV screen, almost like something is loose. I will be scheduling a revisit for those and hopefully I am done with the rattles....
On a side note, It seems the rattles are a common issue across all the new Japanese Luxo's. Two people from work that own a GS300 AWD and M35x have dash rattles. I heard the GS300 and its very bad and Lexus is giving him the runaround, which I couldn't believe. Not sure if its the quality of materials or all the stuff they pack in these dashes.
My dealer is pretty cool about fixing the rattles. They know its not a cheap car.
marcelft
07-10-2018 06:17 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
