Courtesy Light Stuck On
So this morning I was on my way to working and I noticed my driver side courtsey light was on. So I thought I didn't close the door all the way, wrong my message didn't pop up advising me my door was open. So I was like ok? I open and closed the door a few times. Still stayed on and won't dim. All the other doors work just fine. I disconnect the battery for a while. Same thing. I am lost and don't want to take it into a dealership! Any suggestions my fellow kb1 owners?
Take the bulb out.
If it stays on all the time, you need to take the incandescent bulb out ASAP. That will drain your battery quickly. An LED won't drain the battery if you drive it every day.
My only suggestion for you is to follow the wiring diagram to a possible issue, but knowing the RL, I have a feeling it is a random computer error.
Wiring diagram is in the service manual. https://acurazine.com/forums/second-...-noobs-926943/
wirelessnate
2G TSX Problems & Fixes
03-11-2016 01:23 PM
