can you tell how...
There is a link to the service manual in the top of this section.
1 loosen wheel lug nuts
2 raise vehicle with jack
3 secure on jackstand
4 finish loosening wheel nuts and remove wheel.
5 with a broad head phillips screwdriver remove 2 phillips heads screws on totor hat. this might be a little difficult might want to hammer the end of the screwdriver into the screw or maybe try tightening and then loosning if the screws wont budge
6 remove 2 bolts holding on the brake caliper
7 lift caliper up and hang from the spring using wire/cord etc
8 pull rotor off hub. If it doesnt want to budge give it a couple of taps with a hammer or use 6mm bolts through the rotor hat to push them off the hub.
9 reverse all the steps
tzakiel
Oct 15, 2012 04:52 PM
Acuraluvr
3G TL Photograph Gallery
30
Jan 29, 2012 10:42 PM
