Can I go up one size on my RL
Rite now I think I have 245/50/17's with all the potholes here in NYC can I go with a slightly larger tire while retaining the stock wheels?
What size would it be? Or just leave it alone?
You could go 225/55-17 and still use the stock wheels.
You could not go the other way, 275/45-17 because the wheels are not wide enough, but more importantly, they don't exist in that size, but I don't think you want to go that way anyway.
That is my 2 cents
That is my 2 cents
225/55. You need to keep the overall diameter of the tire as close as possible to the OEM diameter. Somewhere within 2% or so. If you don't your speedometer will be off = (percent off) x (pi) %. Use this calculator to see what we mean. Either way, OEM or 225/55, will end up in essentially the same sidewall.
http://www.1010tires.com/tiresizecalculator.asp
You gain nothing. You lose width. To get what you're looking for you would have to go to something like a 245/55/17. There are hardly any tires made in that size. The RL has a fairly large wheel/tire package as-is IMO. You've got about as much sidewall as you're gonna get. I would leave it.
^^^ He wants MOAR sidewall not less.
I'm also in New York and the RL is a soft soft ride.
If tires get damaged, www.discounttiredirect.com road hazard warranty is the answer.
If more cushiness is required, Continental tires are pretty soft vs Michelins.
ExcelerateRep
10-14-2015 08:20 AM
AcuraKidd
09-25-2015 11:18 PM
