Brake Upgrade Recommendations
I am due for an upgrade for my brakes
2007 RL w/ Tech Pkg
I wanted to get Stainless Steel Brake Lines
What Rotors ? (Will Possibly Cryotreat for longer life)
Synthetic Brake Fluid ? (What proper fluid to use , Read Recall about using wrong fluid)
Better pads than stock ?
Any recommendations and links to help out if I decide to purchase
would be most appreciated
2007 RL w/ Tech Pkg
There is a good convo here:
https://acurazine.com/forums/2g-rl-2005-2012-76/what-latest-thinking-brake-rotors-pads-878211/
I've been watching these threads to help make my purchase.
https://acurazine.com/forums/showthread.php?t=877520
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/what-your-thoughts-brake-rotor-package-864909/
And, you also have this fella who has been putting brakes on members rides:
https://acurazine.com/forums/2g-rl-2005-2012-76/adam-here-adams-rotors-873915/
Hope some of that helps.
RemzRR (03-05-2013)
You don't need synthetic bf, Acura fluid is fine, just bleed it regularly if you want to keep air out of the lines and fresh fluid in there, every 2-3 years is fine.. SS brake lines are a good upgrade. I don't have performance brakes, but centric rotors and akebono pads, no issues, stops fine for regular street use.
RemzRR (03-05-2013)
I agree that Acura brake fluid is fine...a good product. My suggestions would be a set of stainless-sheathed lines and that, if you need new rotors, you consider getting cryogenic-treated rotors to match more aggressive pads. The cryo's don't "stop better", but they last longer...
IIDXholic
10-08-2015 07:53 AM
nuldabz
09-03-2015 05:49 PM
