Brake fluid bleed
Old 04-10-2016 | 06:53 PM
jmzb1002's Avatar
Brake fluid bleed
Regardless if I or the dealer bleed the brakes, or if you use a machine vs pumping to bleed, does the fluid in the ABS get bled as well? I have had the dealer bleed my brakes and I have done it too by pumping it manually. Curious if the brake fluid in ABS gets flushed too. Thanks.
Old 04-10-2016 | 07:41 PM
JJones91's Avatar
When you bleed the system you're bleeding everything in the brake system..
Old 04-11-2016 | 08:48 PM
jmzb1002's Avatar
Just curious, because my abs doesn't work, apparently my abs pump is bad and cleaning it out will get it working again. I read somewhere in order to flush the abs pump you jump the relay and run power to the pump so the pump expels all the fluid and pressure.
When I bleed my brakes the brake fluid in the abs reservoir never changes and if I do not run the abs pump, the brake fluid in the abs system doesn't ever get changed.
CybrRdr
2G TSX Problems & Fixes
04-05-2016 09:24 AM
tealt
03-26-2016 02:00 PM
Byruns
03-22-2016 06:32 PM
ericcdong
03-07-2016 10:53 PM
Acuraneewb
03-07-2016 01:50 PM
Quick Reply: Brake fluid bleed
