Brake Assist - what is it about?
Can somebody explain what is Break Assist feature on RL? What it does and when does it kick in?
Another mystery for me is "Electronic Brake Distribution". Any insight here?
Thank you!
Konstantin
Thank you!
Konstantin
Moderator Alumnus
EBD & Brake Assist.
Acura says:
They're the same as TL's.
- EBD
The 2005 RL includes Electronic Brake force Distribution (EBD), which automatically adjusts the front/rear brake pressure to suit conditions, while an anti-lock braking system (ABS) helps the driver retain directional control in hard braking situations. Also included is 4-channel Vehicle Stability Assist (VSA(R)).
- Brake Assist
Brake Assist helps drivers apply full braking pressure in an accident avoidance situation. To do so, a microprocessor continually analyzes and "learns" the driver's normal braking habits-monitoring both the rate of pressure applied and the total pressure that the driver normally applies to the brake system.
If the driver suddenly applies the brakes, Brake Assist brings the system to full ABS activation to help stop the vehicle in the shortest distance possible. It is only activated when the microprocessor detects that certain brake pedal speed and pressure thresholds are reached.
Importantly, Brake Assist assists the driver in obtaining full braking performance in an emergency. The Brake Assist system deactivates when the driver releases pressure on the brake pedal.
GWEEDOspeedo
01-15-2016 10:39 PM
