Anyone know how to auto unlock the doors on the new RL?
Old 11-18-2004, 01:16 PM
ScottRL's Avatar
I have been driving my new RL for a little over a month now and have yet to figure out how to configure the door locking system so that when the engine is turned off, the doors unlock automatically or when the handled is pulled. In my current config, someone always must manually unlock the doors. Anyone know how to do this?
Thanks,
Scott
Old 11-18-2004, 01:18 PM
CGTSX2004's Avatar
I'd start with
But aside from that, I suspect the system is similar, if not identical, to the system in the TL. You would program it using the MID and the menu. As for the specifics, you're on your own to fiddle with it to figure it out.
Old 11-18-2004, 01:44 PM
OG
justinjsw's Avatar
Thanks,
Scott
On the steering wheel to the right you will see 3 buttons...Top button has this ^, middle button says select/reset, bottom button has this V. With the car started press and hold the top button for about 10 secs. The info display below the speedometer in the dash will change to (change settings menu). From here you will be able to adjust all your driver settings including linking and unlinking your remotes.
Old 11-18-2004, 02:06 PM
ScottRL's Avatar
Thanks for the feedback, I finally got it to work. It was neither the
DOOR UNLOCK MODE menu nor the AUTO DOOR UNLOCK menus. It was the DOOR LOCK MODE menu (which actually has nothing to do with lock mode and everything to do with UNlock mode.) The AUTO DOOR LOCK menu applies to all doors.
Thanks,
Scott
mlody
12-04-2019 02:11 PM
BIGxRED
10-19-2015 10:47 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
DementiaPhuro
09-29-2015 05:31 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
Quick Reply: Anyone know how to auto unlock the doors on the new RL?
