anyone can share how..
to remove front a/c cooling fan assembly? one on th drive side is vibrating as though it is going to come off. the dealer wants $300.00 to replace fan. but i can do this myself?? please walk me through it.. thanks
I guess this thread was not on target:
https://acurazine.com/forums/2g-rl-2005-2012-76/ac-fan-turns-get-vibration-868301/
Lets start with a pic.
my guess is you may have to pull the radiator.
- Drain the engine coolant.
- Remove the right upper fender trim, battery trim, left upper fender trim, then remove the upper grille cover.
- Remove the splash shield.
- Remove the air cleaner.
- Remove the automatic transmission fluid (ATF) cooler hoses from the radiator.
- Remove the upper radiator hose and lower radiator hose from the radiator.
- Disconnect the radiator fan control (RFC) unit connectors. Remove the harness clamps and A/C compressor clutch connector.
- Remove the upper bracket cushions, then pull up the radiator.
- Disconnect the fan motor connectors, then remove the fan shroud assemblies and other parts from the radiator.
- Install the radiator in the reverse order of removal. Make sure the upper and lower cushions are set securely.
- Fill the radiator with engine coolant, then bleed air from the cooling system.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
