Air/Heater Blower not working
Old 03-12-2018, 03:50 PM
causeyk's Avatar
on my 2009 Acura RL, the air/heater blower will not blow air sometimes regardless of where I have the fan spead set. Sometimes I turn on the car and it works, but many times when I turn on the car it will not blow any air... What part would be causing this?
Old 03-16-2018, 07:51 AM
4th Gear
dalechris's Avatar
Heater Blower
My blower was intermittent also. Turns out the wiring connection to the motor was loose. It ended up burning the wiring and connector at the motor. Mine was too late to save as I had to replace the motor and connector.
There is a Acura bulletin # 06-006 that addresses this problem. It may not be applicable to your year but it is worth checking. Apparently the wiring harness is too tight and causes this problem. A new sub harness is available P/N 04321-S0K-A00. I would check the connector at the blower motor.
I ended up replacing the harness, blower motor, resistor and relay,
ArizonaTL520
4G TL Problems & Fixes
01-21-2019 06:45 PM
dmartsch
1G RL (1996-2004)
03-12-2018 11:37 AM
mgnk3u
03-10-2018 07:18 AM
jubikej
2G RDX Problems & Fixes
03-02-2018 08:09 AM
Vamsikalluru
01-29-2018 08:39 AM
Quick Reply: Air/Heater Blower not working
