acura RL trunk leak from Fuel cap adapter
I figured out where my trunk leak was coming from but I am not sure how to remove the part. It is the rubber insert around the fuel filler neck that you see when you open the fuel door. It is leaking between the seal and the body of the car after I had some body work done. I also unclogged the drain hole in the bottom of the rubber fill cap adapter but it is still leaking.
I am assuming that it is held on by clips and perhaps using a plastic pry tool will do it but i figured I would ask first before I break something.
The part is# 3174472-SJA-A00 Adapter, Fuel Cap
Filler cap adapter part number 31
Btorres
08-10-2015 04:51 PM
caligirl2k
05-08-2008 10:53 AM
