AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G RL (2005-2012) (https://acurazine.com/forums/2g-rl-2005-2012-76/)
-   -   Acura RL 05 (https://acurazine.com/forums/2g-rl-2005-2012-76/acura-rl-05-a-978311/)
Ed Matt 03-27-2019 01:29 PM
Acura RL 05
I have slight light blue smoke coming from the exhaust when I floor it on the highway. But not always. It also doesn’t respond as quickly as I’d like to. When I change my oil, it’s not mixing nor do I see a leek on my floor but it runs out before my next oil change. Can someone help me with these issues?????
Ron A 03-31-2019 10:26 AM
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum.
rlx015 03-31-2019 07:22 PM
How many miles do you have on the car? Usually blue smoke means burning oil... not necessarily will your car "leak" oil... blue smoke means car is starting to "use" / burn oil - nothing unusual if you have super high miles, or if the previous owner molested it with laying on the gas pedal like a maniac lol
I recommend you top off oil in engine, and take measurements every maybe 2-3 months - see if the level of oil is going down - so if there is no leak, engine is burning oil - or starting to, since you do not necessarily feel the loss of power, but you may over time.
projektvertx 04-05-2019 08:29 AM
How old is the PCV valve? Sometimes changing that might help alleviate the burning. However, if it's from a more serious cause doubt that will fix the issue completely.
Ed Matt 05-06-2019 10:42 AM
Ed Matt 05-06-2019 10:45 AM
Not sure how old it is but I’ll look into it
