2nd Gen RL TSB Information
TSB's:
I think it's working now. If anyone has a problem, send me a PM (not too many though lol).
IMPORTANT NOTICE
UPDATED 6 DECEMBER 2010
We have regained our access. Follow these instructions.
1. Open this link .
2. Select any entry to fill in the information for make, year, and model, then click on "submit vehicle information".
3. Open any of the listings.
4. You can now open the below listed links.
Many thanks to TSXV6Guy for sharing this method with us.
2004:
TSB 04-028: 2005 RL: TQI and New Model Information
TSB 04-032: 2005–08 RL: TQI of the DVD Navigation System With Voice Recognition
2005:
TSB 05-003: 2005 Acura Paint Codes
TSB 05-005: (2005 RL) Product Update: Front Door Speakers and Driver’s MPCS Unit
TSB 05-008: (2005 RL) No Sound From the Audio System
TSB 05-018: (2005-2010 RL) Navigation System Information and DVD Information and Inspection
TSB 05-021: (2005-2006 RL) Rattle From Front Suspension Area or Front Brakes Squeal At Low Speed
TSB 05-026: (2005-2007 RL) No Real-Time Traffic on the Display
TSB 05-027: (2005 RL) Product Update: PCM Software May Not Allow the Transmission to Upshift Into 4th Gear or May Cause an Engine Shudder
TSB 05-030: (2005 RL) Rattle From the Rear Shelf
TSB 05-031: (2005 RL) MIL Comes On With DTC P0135 or P0155
TSB 05-032: 2006 Acura Paint Codes, Exterior and Interior Color Code Locations
TSB 05-040: 2006 RL: TQI and New Model Information
TSB 05-045: (2005-2006) Product Improvement Campaign: Tire Valve Cap Replacement
2006:
TSB 06-002: (2005-2010 RL) Front Subframe Removal Adapter
TSB 06-017: (2005 RL) Instrument Panel or Center Console Creaks or Rattles
TSB 06-023: (2005 RL) MIL Comes On With DTC P0116
TSB 06-030: 2007 RL: TQI Information
TSB 06-034: (ALL ACURA MODELS) Vehicle Pulls or Drifts, and/or Steering Wheel Is Off-Center
TSB 06-047: (2005-2006 RL) Auto Door Unlock/Lock Does Not Work When Shifting To/From Park
TSB 06-049: (2005 RL) AFS Indicator Comes On With DTC B2130
TSB 06-053: 2007 Acura Paint Codes, Exterior and Interior Color Code Locations
2007:
TSB 07-001: (2005 RL) Door Mirrors Stay Tilted Down After Shifting Out of Reverse
TSB 07-003: (2005-2007 RL) Fuel Vapor Lock
TSB 07-009: (2005-2008 RL) Windshield Wiper Doesn’t Clean Snow or Slush From the Windshield
TSB 07-017: (2005 RL) Safety Recall: Fuel Pump Relay May Cause Engine No-Start or Stalling
TSB 07-022: (2005-2007 RL) Navigation Software Updates for Daylight Saving Time (DST), DVD Read Error Message, Reboots After Driving 1.5 Hours, and Other Listed Symptoms
TSB 07-026: (2005-2006 RL) Pinging, Rattling, or Squealing During Light Acceleration
TSB 07-029: (2005-2007 RL) Rear Brakes Squeal
TSB 07-034: 2008 RL: TQI and New Model Information
TSB 07-040: 2008 Acura Paint Codes
TSB 07-041: (2005-2007 RL) Brake Pedal Is Low and Feels Soft
TSB 07-047: (2007 RL) Product Update: Improving the Elevation and Clock Settings
TSB 07-061: (2005-2008 RL) Safety Recall: 2005–08 RL Power Steering Feed Hose Leak
2008:
TSB 08-002: (2005 RL) Front Accessory Power Socket Lid Won’t Stay Closed
TSB 08-003: (2008 RL) Product Update: AcuraLink Does Not Receive Messages From Acura
TSB 08-006: (2005-2008 RL) MIL Comes On With DTC P0401
TSB 08-021: (2005-2007 RL) AcuraLink Messages Cannot Be Read, There Is No XM Radio or Traffic, or XM Channels Are Wrong
TSB 08-022: (2005-2006 RL) Outside Rearview Mirror Is Loose
TSB 08-029: 2009–10 RL: TQI of the Navigation System
TSB 08-030: 2009 RL: TQI Information
TSB 08-035: (2006-2010 RL) DVD Read Error, or No Route Displayed, and Navigation DVD Is Scratched
TSB 08-036: 2009 Acura Paint Codes
TSB 08-046: (2009 RL) Audio Unit Displays CODE After Using Auto Select
TSB 08-049: (2005-2007 RL) Drive Belt Auto-Tensioner Replacement Instructions
TSB 08-050: (2005-2009 RL) Time on Display Changes Randomly
TSB 08-059: (2005-2009 RL) Front Door Outer Handle Sensor Does Not Unlock the Door
2009:
TSB 09-001: (2008-2009 RL) XM Notes Are Duplicated; Wrong Map Colors When Off-Route; Wrong Image Appears During Navigation Talk Button Tutorial; and Other Listed Symptoms
TSB 09-007: (2009 RL) Long Crank Time or Hard Start After “Hot/Warm Soak"
TSB 09-013: (2005-2009 RL) Immobilizer System (Type 5)
TSB 09-015: (2005 RL) OnStar Control Unit Replacement for Lost Minutes (Units)
TSB 09-021: (2009 RL) MIL Comes On With DTC P0455 or P0456
TSB 09-022: (2005-2009 RL) High Mount Brake Light Cover Is Loose or Falls Off
TSB 09-025: (2009 RL) Steering Angle Sensor Causes False SAS, VSA, CMBS, or AFS Messages
TSB 09-026: 2010 RL: TQI Information
TSB 09-035: 2010 Acura Paint Codes
TSB 09-042: (2005-2009) Door Outer Handle Cover Is Loose or Missing
TSB 09-053: (2009) USB Folder Number in Upper Display Is Wrong or Limited to Two Digits
2010:
TSB 10-021: (2009-2010 RL) 2009–10 RL: Moisture in the Taillight
TSB 10-028: 2011 Acura Paint Codes
TSB 10-031: (2008 RL) In Florida, Navigation Unit Reboots When Destination Is Entered
TSB 10-038: (2009-2010 RL) Rearview Camera Is Aimed Too Low or Is Loose
TSB 10-047: (2005-2007 RL) Safety Recall: Master Cylinder May Be Leaking
TSB 10-050: 2011 RL: TQI Information
2011:
TSB 11-002: (2005-2010 RL) Whistle, Whine, Squeal, or Howl While Driving Between 20–45 MPH
TSB 11-011: (2005-2010 RL) Door Pocket Is Loose or Won’t Stay Closed
TSB 11-013: 2012 Acura Paint Color Codes
TSB 11-030: 2012 RL TQI Information
2012:
TSB 12-008: 2013 Acura Paint Codes
TSB 12-029: (2007-2009 MDX, 2009-2010 RL, 2009-2011 TL) WARRANTY EXTENSION: TORQUE CONVERTER W/ SOFTWARE UPDATE FOR LOCKUP FUNCTION 8YRS/105,000 MILES
TSB 12-038: (2005-2011 MDX) Vibration in Gear or Knock Noise on Acceleration
2013:
TSB 13-013: Safety Recall: VSA System Unexpectedly Activates (2005-2006 MDX, 2005 RL)
IMPORTANT NOTICE
1. Open this link .
2004:
2005:
2006:
2007:
2008:
2009:
2010:
2011:
2012:
2013:
The following 3 users liked this post by csmeance:
emailnatec
29
09-28-2018 04:27 PM
RSpyder
09-30-2015 12:46 AM
