2008 RL rear dome light- Only one of two bulbs is working. Changing bulb not helping
2008 RL rear dome light. Only one of the two is working.
I got a new 5W bulb 04110-SWA-305 from dealer and changed it but does not help. If one is working, I believe that it cannot be a fuse. Any suggestion to fix it? |
Check wiring, something could be loose
Also check for a spot of corrosion in the socket. I've had a couple of devices lately where this was the problem. No contact, no work.
Pop your lenses, unscrew the assembly and do some simple test-light checking.
Worst case is you jumper-wire it. Best case is it fixes itself... :tongue: |
