2006 RL with ZDX RIMS AND TIRES?
Old 05-26-2013, 06:44 PM
8th Gear
TorontoSars's Avatar
Hi, does anyone know if the rims and tires from a factory 2013 ZDX would work on a 2006 RL? The factory 2013 ZDX tires are 19" 255/50/19 5X120 bolt pattern offset 45.
Old 05-26-2013, 08:56 PM
Carbon Legend's Avatar
You will need spacers
these are the tire sizes needed with upgraded wheels
OEM 17": 245/50/17
18": 245/45/18
19": 255/40/19
20": 255/35/20
TorontoSars (05-26-2013)
Old 05-26-2013, 09:44 PM
BDoggPrelude's Avatar
Like said above, wheels will need spacers to clear the front brakes. Tires are not even close.
Old 05-27-2013, 09:54 AM
Tony Torque's Avatar
I just put 19" MDX wheels on my 06 RL 19x8.5" +45 offset had to use 6mm spacers in front mandatory to clear calipers! Im running 255/40/19 tires all around. Drives great zero issues.
Old 05-28-2013, 01:34 AM
8th Gear
Tony Torque can you post pictures??
Old 06-06-2013, 07:25 PM
Jhampster's Avatar
I also running ZDX wheels on my 05' RL. 6mm spacers and 225/35 tires with H&R springs.
Old 06-06-2013, 07:26 PM
Jhampster's Avatar
ignore the huge curb check on the driver wheel, thats been repaired hahah
Old 06-06-2013, 09:02 PM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
Acura should have just used these wheels from the factory. Or their concept wheels.
Old 06-07-2013, 12:11 PM
StReCh4130's Avatar
Car looks good on those wheels. It's great to know of other OEM wheel options.
Old 01-27-2017, 06:48 PM
fuzzysig's Avatar
how much clearance you have between caliper and wheel?
Old 01-27-2017, 07:12 PM
MSW 6SP's Avatar
Since he hasn't signed in for the last 42 months I doubt you will get an answer
rseb4agze
05-03-2016 07:41 AM
booma1218
05-03-2016 07:39 AM
lland
10-04-2015 04:47 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: 2006 RL with ZDX RIMS AND TIRES?
