2006 Acura RL - Fuse Box Question/CEL
Hey,
I am wondering specifically which fuse to pull to reset Check Engine Light notification. Today I got a "Check Emissions" CEL and code P0401. Before I take this to the dealer, my plan is to reset the fuse and proceed.
If the light comes back on, head to Auto-Zone for a OBD2 scan.
If the code says EGR, I plan to remove the valve and clean it. From my readings, the EGR valve is located at the right side front of the engine. A fairly easy fix.
If cleaning the EGR valve doesn't work, try a bottle of Seafoam through the gas tank on a full tank.
Am I on the right track here?
Got in my car this morning and CEL light was off as well as Check Emissions warning. I read that this can be caused by a loose gas cap. I did just get gas before the CEL came on. Checked the cap and it was on and tight.
Weird. I'm planning on monitoring it and other system functions with a bluetooth OBD2 scanner.
Side note: I was very low on fuel when I gassed up. I'm rarely that low. 0 miles on dash computer.
drewdeezy03
Sep 3, 2015 08:04 PM
