2005 RL Side Mirror
First thing I would do is pop out the passenger side mirror to see if anything is preventing your mirrors from going side to side. Does your driver mirror operate as it should?
I'm not sure if you can reset it but you can do a test on the power mirror actuator as stated in the manual to check the continuity of the actuator.
Using a HDS follow these steps.
Select Body Electrical from the System Select Menu. Select Function Test, then the appropriate power mirror function test.
rockyboy
08-04-2024 10:35 AM
sockr1
10-01-2015 01:31 AM
