2 Remotes in the Car: Which One Wins?
If you get in the car with your better ½ who also has a remote, which one will be recognized by the car for the seat (& etc) settings?
I believe the car recognizes the Fob when it's within 3-feet of the vehicle. That's why they tell the driver to approach the vehicle first so the seat/steering wheel will adjust to the person who is going to be behind the wheel.
Originally Posted by lland
If I'm with my wife, I race her to the car. If she gets there first, I end up listening to the Oprah station on XM.
LL
LL
And for us, it is who touches the handle first with the closest fob.
Overriding?
Don't feed the...WTF?
Originally Posted by Sylvain
I was afraid this would be the case. If the driver is not the first one at/in the car, is there a way for the driver to "override" the setting (other than hitting the appropriate button inside the driver door)?
You could deactivate her keyfob, but then it wouldn't link to the car at all. And hopefully I'm not missing something here - but why would you want to go through all of the trouble to override the settings? The override is actually to push the driver button. Was there something else you were looking for?
I don't mean that to sound like an ass, I'm just not sure what the big deal about pushing the driver button is?
I'm not sure about that one. Now that I think about it - I'm not even sure that my car makes any changes between the two. I think it's more that my wife drives my car once a month (or less) and probably hasn't bothered setting stations and such for the trip to the store.
Originally Posted by GLowrdr
...I'm just not sure what the big deal about pushing the driver button is?
LL
LL
Driver Button Doing it All?
I believe if you push the button, it only moves the seat, mirrors, and steering wheel, leaving all other settings (radio, climate, etc.) alone.LL
Simple solution: Always open her door for her and make sure you get closest to the car first!
There was a thread on this before, and I cannot recall who did the test, but 2007+ models keep setting of who unlocked Driver's side door last. (My 2005 does not behave that way)
Another solution that does not require you to always be the perfect gentleman.
You are Driver 1
Your wife is Driver 2
Let's say you get in the car, twist the ignition and the MID says Welcome Driver 2, naturally, because she got there before you, or whatever other reason.
Turn the ignition off, use your key fob 1 to lock and unlock the car. Twist the knob to ignition on position, and it will say Welcome Driver 1.
Warning:
When you lock the car, you will notice that a red alarm system armed light turns on in the dash. DO NOT open any doors, otherwise the alarm will go off. If you just lock the car and unlock it immediately, it will have the effect of changing the profile to that of whatever remote was just used.
You are Driver 1
Warning:
Unlock Again?
Originally Posted by Chas2
(...)Turn the ignition off, use your key fob 1 to lock and unlock the car. Twist the knob to ignition on position, and it will say Welcome Driver 1.(...)
LL
LL
Other Related Thread
Originally Posted by getakey
(...)There was a thread on this before, and I cannot recall who did the test, but 2007+ models keep setting of who unlocked Driver's side door last. (My 2005 does not behave that way)
Thanks Chas2. Would hitting the unlock button on the remote even before opening my door work too? (avoids having to fool around with the ignition) Or does someone have to go through a lock/re-lock cycle to make this process work?
I think what happens is that I can set the car to Driver 1 with my fob by unlocking the door. However, if my wife is ahead of me, even after I set it to Driver 1 with the remote, her touching the handle with her fob in her purse will change the setting from Driver 1 to Driver 2.
Chas - I do not believe that is true. The act of unlocking the car determines the settings. For example, if the car was never locked from previous use, opening the car door (whcih requires grabbing the handle) will not change the settings from the previous use. The settings would inly change if your wife touched the outside of the handle after you unlocked with your FOB.
Yeah, that is another thing, how you open the door. She very often closes her hand around the whole handle locking, unlocking, locking, the car is beeping away and she is cursing it because she cannot get in the car.
The solution, other than trying to train her, is to open the door for her, "as the proper gentleman should"
Chas - totally understand
I just had an interesting thought. I know you cannot lock your FOB in the car, but can you lock FOB2 in car if you have FOB1 in hand? Does it matter whether you use the FOB1 directly or touch the handle?
Similar, can you lock FOB2 in trunk in same situation? (not saying I want to lock my wife in trunk, just her purse.)
connolley, welcome to AZ! .....and I guess that's one approach to the problem.
This will be an issue as we're driving to Colorado in three weeks in the RL (I insist on not taking the Pilot this year!).
Another take on the two remote dilemma...
Yesterday I went to my son's baseball game. Dropped my wife and other son at the field and went to park (you don't want to park too close for fear of foul balls).
I tossed her bag in the trunk and tried to shut it. After about five times of it beeping at me and popping back up, I (finally) realized her fob was in the bag and the car wouldn't let me lock it in the trunk.
Wondering what would happen, I took both her fob and mine, locked the car, and held them in my hand as I grabbed the door handle. At first I thought the confused car would simply explode but it just unlocked, so I got in, sat down, and started it up. Got the "Welcome Driver 1" message so I guess if the two fobs "hit" at the same time, the car will just stick with the last one recognized.
LL
LL
SinCityTLX
10-07-2015 01:24 PM
