05 RL Headlight lens broken
9th Gear
Is there any way to replace just the plastic lens cover? Mine is cracked but everything else works fine. Thanks for the help.....
Doubt it. Look on acuraoemparts.com
It would seem that the unit is one piece at over $1000 each. This is sort of typical with modern headlight units, they come as a sealed unit, and you don't just replace the front lens.
Good luck. Maybe your comprehensive will cover part of it. My insurance seems to use comprehensive anytime glass is broken. You wonder if polycarbonate is considered the same as "glass"
