'05 Acura RL airbag code
Stay Out Of the Left Lane
Received 1,241 Likes
What makes you think the 61-1 code is airbag related?
[ the car is anouncing airbag system may be deactivated then in the massages it displays 61-1
QUOTE=NBP04TL4ME;15228698]What makes you think the 61-1 code is airbag related?[/QUOTE]
Could be a catch-22 in that the a bad or dying (low voltage) battery could be kicking this code out. I would start by having your battery tested. A bad or dying battery has been known to manifest itself in all sorts of electrical oddities.
Battery may test good and it could be your alternator, but again I would start with having the battery tested.
What is the batterys appropriate voltage
Usually at rest, a battery will register around 13.2 V or higher. But, we don't know if you might have a draw causing a lower voltage reading. That's why the load test is important. With modern testers, the battery doesn't even have to have a 100% full charge to get that info.
It's more complicated than just voltage, but this is a good indicator. You need to have the battery tested to see if there is a drain on the battery itself, or a defect within.
[ i will have the batterey checked i hate having warning lights
QUOTE=NBP04TL4ME;15228752]It's more complicated than just voltage, but this is a good indicator. You need to have the battery tested to see if there is a drain on the battery itself, or a defect within.[/QUOTE]
Depends whether the engine is running or not. And its easy to check the battery yourself.
https://acurazine.com/forums/showthread.php?p=14546038#post14546038
LINK: How to maintain a battery
https://acurazine.com/forums/showthread.php?t=775689
NBP04TL4ME (11-08-2014)
OP - Keep us posted.
Still betting on the battery.
I looked further into this (Google "Acura code 61-1") and it seems half of the posts say it's "low battery voltage" or "battery voltage malf" and the other half say "open circuited in drivers seat belt buckle switch."
If it were me, I would double check that my battery connections are good, tight and corrosion free both at the battery and the other ends. From there, go to a dealer
Believe the part number is 31551-SJA-A01ZA. You can hit up one of the vendors here on AZ, your local dealer or one of the many on line. I'm local to Bernardiparts.com and use them. Their prices are good but IMHO they do make some of it back on shipping costs.
[Thanks somehow i took it in for a service and when i got home to check under the hood it was gone!! Im going to check with them how much it is
QUOTE=NBP04TL4ME;15232070]Believe the part number is 31551-SJA-A01ZA. You can hit up one of the vendors here on AZ, your local dealer or one of the many on line. I'm local to Bernardiparts.com and use them. Their prices are good but IMHO they do make some of it back on shipping costs.[/QUOTE]
You night want him to first check with whomever serviced your car. Can't imagine they would have a lot of RL battery covers laying around........
[I checked with them they said they have no clue. So il just replace it
QUOTE=NBP04TL4ME;15232457]You night want him to first check with whomever serviced your car. Can't imagine they would have a lot of RL battery covers laying around........[/QUOTE]
OP - Any updates??
update
Ok guys new update , I left the issue alone for awhile and it cleared itself. I'm convinced it may be the battetey causing this because now my steering wheal won't bring itself to the saved position any more, the car will also give out airbag code and if I leave it off for an hour or so it clears itself and won't show it's ugly little head for awhile. Seems to me that your guys suspicious about the battery are right has this happen to anyone on a dying batterey sign. Thanks guys and sorry for the long time to update been real busy with college work
mada51589
05-03-2022 08:54 PM
elietania
4G TL Problems & Fixes
09-05-2015 06:52 AM
