Tire Pressure
Car Crazy for Sure!
Recommended tire pressure is printed on the door frame sticker. And it's in your Owner's Manual. That # is: 33 lbs, front and rear, read when tires are COLD. Also, remember that tire gauges are calibrated at sea level. I'm at 6,200 feet and have to add approx. 3.5 lbs reading to what I want in the tires. So, if I want 32 lbs my gauge has to read 35.5 lbs. I cheat a little on that. I've been putting in 34-35 to have an altitude adjusted 31-32. I know...a little less than what Acura says. Generally I try to stay at 32 lbs cold reading.
mbm0420 (11-05-2012)
A tire pressure guage shows the difference between the pressure inside the tire and the outside/ambient air pressure. Note that a tire gauge on the stem of a flat would show 'zero' pressure, not the usual 14.7 psi at sea level or 11.7 psi at 6000' MSL.
Consider this: if you inflate your tires to 33 psi at sea level and then drive to 6000', your tire gauge would indeed read 36 psi - but the tires would now be overinflated, with a narrower tread contact pattern, and a stiffer, harsher, more unyielding ride. At 6000', you still want to read 33psi on your tire pressure gauge (assuming you like OEM recommendations), temperatures being equal. So, as we drive to higher altitudes (and the difference between internal tire pressure and ambient pressure increases), we would have to release air from tires, not add more, to maintain tire shape.
Here's a website discussion of this topic: http://www.tirerack.com/tires/tirete...jsp?techid=167
With all that said, like you, I prefer a slightly higher tire pressure - maybe 2psi above recommended, cold.
hope this is helpful. Smooth driving,
woody
Cold Out
I live just outside of DC and in the am I get the warning that my tires are low. Later in the day after driving on them, they warm up and info warning disappears. Should I fill them up in the am to 33lbs in the am when it is cold? What is the best approach?
mrgold35
I am also a high altitude RDX driver with my elevation varies between 5000ft-8000ft in ABQ, up to 11,000 feet in Colorado, and sea level when I visit my bro in LA. I've noticed there is a 2-3 psi higher reading on the hand held gauge compared to the TPMS in ABQ (5200 ft average).
I tend to rely on the TPMS to be more accurate and I adjust up on my hand held gauge to "try" to equal the suggested PSI. I usually put in 33-34 in the summer with the hand held gauge because the psi always goes up when the temp is +95 degrees. I usually put in 35-36 in the winter months because of the cold mornings to read 32 psi on the TPMS when below freezing.
I started doing this because I took the kid skiing in Pagosa Springs, CO, a few years ago and the morning temp was about 7 degrees. I had the recommended 32 psi when I left ABQ the day before; but, the TPMS alarm when off with a warning of low tire pressure at 27 psi. It wasn't until lunch time and 40 degrees warmer when the TPMS stop alarming and the TPMS read a normal PSI. No warnings since I started adding the extra 2-3 psi in winter months.
PS Low tire pressure is a bigger problem than higher pressure. Tire pressure that's very low creates serious problems with vehicle handling - so, if you're gonna be off, be high.
Just to keep this on your minds as you bring your vehicles in for the first A1 service, know that some dealers (like mine) add air above the rating plate 33 psi during the cold months. I picked mine up reading 35-37 psi. I called up the dealer and questioned this and the service writer stated that it was intentional to keep the cold temps from setting off the tpms alarms, which is actually code for preventing idiots from calling them all winter about the tpms alarms. I'm annoyed by the practice because it may lead to premature center tread wear. Yes, I'm the dork with a digital gauge that actually checks his pressure regularly.
I'm not Amber; but I got a gauge at Radio Shack?, IIRC. Decent digital gauge, window buster and seat-belt slasher all in one. I'm sure there are cheapies that don't work worth a nickel; but this one seems to be accurate(when compared to the analog reading on the inflator).
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
Sears had their digital gauge at half price for a bit over the weekend(check SlickDeals and maybe set up an alert). Our little multi-tasker is in the door pocket...likely with dead batteries since I haven't checked it in a while.
mugen_kid
11-13-2015 10:38 PM
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
HeloDown
09-08-2015 06:51 PM
