Rdx 2016 tpms
Rdx 2016 tpms
Hi,
I've been lurking around these forums ever since I got my RDX Tech 2016 (Canada) in July. Thanks to all who contribute and provide great information.
I have a rookie question. It's that time of the year when I need to start looking for winter tires. I have a question regarding the TPMS. I plan to purchase winter tires online possibly pre-mounted on rims with TPMS sensors. If I do, will the new TPMS sensors automatically work on the car or do I need to bring it to the dealer to get it programmed?
If I need to get it programmed, does that mean that when I change the tires back to my all-seasons, I would need the dealer to reprogram the car to detect the sensors of the all-season tires?
Thanks!
Thanks!
I have already purchased my winter tires and aluminum rims as a discounted package deal at the dealership. The parts manager assured me that the TPMS system does not require programming like my previous Toyota RAV 4 needed.
As long as the replacement sensors are compatible with the OEM sensors, the system will automatically connect with them.
This is also an important feature even if you rotate your existing tires to another location on the vehicle. The system will automatically know which position each tire is in.
My experience with honda/acura products with TPMS is this - if you have a display that shows the actual PSI of each tire, then it will automatically detect the compatible TPMS sensor (after driving about a 1/2 mile or so). If it's a hidden TPMS system (meaning it just has a dummy light if it detects one sensor out of whack) they tend to need to be programmed. My son's '12 Civic had this, and every time I put on the winter rims/snows/tpms sensors I had to have the local shop re-program the sensors. Real Pain. But the RDX, my former MDX, and the wife's TL all have self-programming sensors, which makes things much easier.
andy
andy
I am about to purchase a set of winter tires without TPMS sensors. However, my question is: where does the TPMS alert come on on the dashboard? Will it come on the MID? If so, can I take the alert off by hitting the Info button on the steering wheel, much like the low-gas alert? With the low-gas, you get the alert on the MID when you start the car but then hitting Info will take it away. I want to be able to see other information (such as the compass) on the MID and would hate to see the TPMS alert on it constantly, throughout the winter.
Thanks in advance.
Thanks in advance.
mrgold35
You can purchase TPMS sometimes for $25-$35 each on-line.
The Original Shawdy
Thanks in advance.
Thanks in advance.
Also there are two types of sensors. Oem replacements which are not compatible with all makes and models but learn on their is after a short drive. My 2014 TL can only use the original set or the ZDX set. Then there's the aftermarket which need to be programmed.
So I purchased a set of mint 2014 Accord rims for my winters with tpms sensors already in them. Two things, the offset is a little different and they run awfully close to the suspension so there's a bit of a red flag and secondly, the tpms seemed to work properly at first but upon driving, the error came up as problem with the system and none of them are registering. My guess is the sensors are not "self programming" but the system is perhaps?
The Original Shawdy
First off. The accord rim specs most likely have a different offset. Most likely higher then the RDX hence being close to the factory suspension. Secondly not all oem sensors are compatible. Their are certain vehicles that may run the same TPMS. For example: my 2014 TL only shares TPMS with the ZDX and no other model.
ja17
09-07-2015 06:08 PM
