Lug Nut Socket size?
Sylvain (07-23-2015)
19mm (or 3/4") is a little loose but 18mm doesn't fit so it has to be one or the other. There is only .002" difference between 19mm & 3/4" so either one will work.
wb2ee - I'm curious about the torque you used. The owners manual specifies 80 lbf∙ft.
Damn 80lbs isn't much. All my other Acuras and Hondas have been 92-94lbs/ft. Haven't swapped lugs or wheels yet though to need to know the torque spec. Good to know. Is the thread pitch 12x1.5? Been in the 14x1.5 on the TL and lug options are limited.
neuronbob
23
07-16-2019 10:48 AM
ExcelerateRep
10-14-2015 08:20 AM
