2017 Acura RDX Rear Camber
Old 07-03-2019, 11:30 AM
Chip Davis's Avatar
Just had my 2017 Acura RDX 2WD aligned (4 wheel) at the dealership. Adjustments were performed with the exception of the rear camber, which obviously cannot be adjusted. Camber for left rear wheel was -1.5 and right rear wheel was -1.7 (out of spec). Service guy said sorry, but we can't do anything about it. Much worse when loaded and makes a nice car look like crap. Any suggestions to correct this issue? Could this be a potential warranty claim? Car is two years old and has 31,000 miles.
Old 07-11-2019, 11:06 PM
Administrator
Ron A's Avatar
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum.
Old 07-19-2019, 05:42 PM
csmeance's Avatar
Received 1,987 Likes on 1,411 Posts
this should be a warranty item as the springs have sagged beyond service limits in 31K miles. How often to you load the RDX to it's weight carrying capacity?
Old 07-19-2019, 07:18 PM
Chip Davis's Avatar
Never been loaded to capacity. Back is empty 90% of the time.
Old 07-22-2019, 10:32 PM
The6ix's Avatar
You can put in s2000 rear ball joints that have a rear camber adjustment and correct it. A member by the name of Radical did that after lowering his Gen 2 RDX and corrected it. He has a thread with all the specs and info. Check it out.
gatrhumpy
07-25-2020 02:45 PM
I Hate Nissans
2G NSX (2017+)
03-03-2017 08:48 AM
clawber
12-17-2016 08:53 PM
LASoCal
12-09-2016 04:01 AM
stewie20068
1G TSX Problems & Fixes
01-20-2013 01:59 PM
Quick Reply: 2017 Acura RDX Rear Camber
