P0848-Powertrain
P0848-Powertrain
I just got Engine Light code P0848-Powertrain on my 2016 RDX AWD with mileage 71,xxx
it says Transmission Fluid Pressure sensor/switch "B" Circuit High
i searched but it relates to 3rd gear pressure switch plate?
anybody have DIY or repair guide?
is this related to TSB: Torque Converter Lock-up Clutch?
part# and diy would be appreciated.
thanks
thanks
You sure on part#??
when i see 2016 it has two different sensors are there.
Diagram#8 is located outside of transmission and diagram#7 is inside of transmission??? They have different part no.
Switch Assembly, AT Oil Pressure - Acura (28610-R36-004) Acura Parts For Less - https://www.acurapartsforless.com/oem-parts/acura-switch-assembly-at-oil-pressure-28610r36004
i am going to replave transmission oil first and see it solves problem. If not i will change diagram#8 sensors one by one.
If You compare both pictures,they appear to be two different transmissions.You will have to crawl under and compare images to Your transmission. Both images are for 2016 RDX AWD.
ok. i changed transmission fluid and also changed transfer case fluid while i am changing.
of course it got smooth gear shift feeling and not CEL came on. so i will keep you guys posted for update.
it's possible to have CEL light on if lower transmission fluid? when i took out old fluid, i had about 3 Liters so i's about 0.1 L short from manual says but i doubt it will cause CEL to trigger.
hope everything is ok for now
thanks
thanks
deepa1600
09-15-2020 01:27 PM
darocc
4G TL Problems & Fixes
01-22-2015 07:22 PM
