One Side of HVAC Not Working
My wife's 2014 RDX has been blowing hot air thru the driver's side vents when operating the air conditioning--the passenger side works without issue and is cold. I swapped out the driver side blend door/air mix motor this morning, and the AC finally pumped cold thru the driver side. However, a few hours later and it's back to blowing 90° air when on lowest AC setting. I looked at the actuator while controling the temperature dial, and I could see the gears moving in concert to the temperature control changes. Any thoughts/ideas on what could be happening and how to fix?
I also once argued with people until I charge the freon.
hutt132
Dec 5, 2023 10:55 PM
kingofbytes
Sep 11, 2015 09:29 AM
