Crooked Steering Wheel
I noticed a while back that when I'm driving my steering wheel is turned a few degrees to the right. Not much, but noticeable. If I drive with the wheel exactly straight the car drifts to the left.
So two weeks ago I paid for an alignment at the dealer hoping it will solve the problem, but it was still the same. Then I took the car back again the following week, they checked again, and said maybe its a wheel pulling the car to the left. They rotated the tires, and nothing changed.
After the second alignment I noticed the base of the steering wheel was not lined up with the dash. It's slightly crooked as shown in this picture:
Then while driving I noticed that if I line up the wheel to the crooked base the car goes straight. So I dont think it's a problem with the wheels. I think the steering wheel itself is crooked. Then I remember last year I had a ticking sound inside the wheel and the dealer took it apart to find the problem. I'm thinking maybe they didnt put it back correctly?
I brought the car back to the dealer and explained this to them. They kept it for 3 days and said they found something wrong with the steering subframe and they fixed it. When I got the car I noticed the steering wheel base is still crooked, and the car still drifts left when I straighten the wheel. Nothing was fixed.
I'm thinking this problem is specific to my car, but does anyone else have a crooked steering wheel base?
Ottoman...I saw another thread where someone had the exact problem as yours (this is your first post on this correct?)....I will try and find it for you.
I found it:
https://acurazine.com/forums/2g-rdx-2013-2018-404/steering-wheel-tilt-issue-902532/
I found it:
I found it:
https://acurazine.com/forums/showthread.php?t=902532
I found it:
I'm wondering if it might just be the plastic cover that is crooked. I'm going to try to play around with it and see if I can loosen some screws and readjust it.
It still doesn't answer why I have to drive with my steering wheel tilted right though.
When I line up the steering wheel to the crooked base, the car goes straight. That's why I suspected the entire steering assembly might be crooked. If it is just the plastic molding then I can fix the asthetic problem.
But still the steering wheel will not be straight when I'm driving.
I dont want to take the car to the dealer service a 4th time. I've contacted Acura Client Care about it and they left me a message. I have to call them back and hear what they say.
Don't obsess about the trim piece. That just muddies the issue and most are a bit crooked. Focus on the steering wheel. If the car doesn't pull in one direction when on a perfectly flat road then the alignment is probably OK and the wheel just wasn't centered when they did the original alignment at the factory and didn't bother fixing it at the dealership alignment.
In another thread, you mentioned you've ordered a Porsche to replace your RDX. I'm a little curious as to why you continue to pursue this issue with Acura. Seems like you could let this one go.
Letting it go crossed my mind, but I have a dilema. I commute 50 miles a day to work and dont want to put all those miles on the Porsche. So I might keep the RDX to split the miles. Plus I paid for 8 year/120k extended warrantee, although they told me I can get my money back since I'm still in the standard warrantee period.
Another (not so thrilling) option is to sell the RDX and lease a plug-in hybrid electric car, and use that for the daily commute. The way I figure, I'll be saving the $450 a month I spend on gas and that money can go towards the lease. It's close to breaking even. Plus there's a tax break. Plus I can ride the HOV lane alone and get around the traffic.
Whatever, the Porsche comes the week of May 26. I'll cross that bridge when I get there.
I speak (er, write) with a little experience here. For eight years, my daily commute was 55 miles EACH WAY, racking up nearly 30,000 miles a year. When I did so, I wanted to be in the most comfortable, safest vehicle I could afford at the time.
Obviously YMMV. But if you decide to keep the RDX, I guess it can't be all that bad after all.
And hopefully you will not become as familiar with the Porsche service department as you are with Acura's.
Did you get any feedback from Acura client care? My 2013 rdx has the same issue, which is extremely annoying to me. I have to constantly fight with the steering wheel and feel that I can not control the car some times.
Please advise if you get any updates from Acura or if you have this issue fixed?
I didnt realize the base was crooked until after the 2nd alignment.
It's obvious the dealer doesnt know how to fix it so it feels like a waste of my time. After everytime they attempted to fix it I was told the steering wheel was now straight when I picked up. Then I drive a few miles and its exactly the same.
If it ever gets fixed I'll post it.
Thank you for the updates.
I will go to my local dealer to see if they know how to fix it.
Will keep posting the progresses.
They contacted me on Monday and said to just bring it back to the dealer again...for the 4th time. I still have to make the appointment.
So I dropped my RDX off at dealer service last week. They said it's out of alignment....after they aligned it three times already. This time they wanted to charge me for another alignment. I basically said screw you. I already paid for an alignment that was never satisfied. Acura Client Care was no help, and they are taking the dealers side.
Long story short...I'm getting rid of this car once my new one arrives. The new RDX has been nothing but a hassle since day one. It'll be decades before I even think about buying another Acura. Best of luck to all.
rockyboy
08-04-2024 10:35 AM
EvilVirus
12-10-2015 07:38 PM
