Acura APP
Old 07-15-2017, 10:06 AM
7th Gear
grecon's Avatar
Acura APP
Hi - I was using the acura app and it is showing 3 maintenance alerts - the car has 300 miles on it and it is in the garage and the stupid app is telling me oil pressure warning, charging system warning and electronically controlled power steering warning. Seems stupid to me since no idiot lights are on and the car is fine. Does anyone else have issues using this app? I am considering deleting it since it isn't accurate. Thanks
Old 07-15-2017, 12:14 PM
RDX-Rick's Avatar
I think this older thread should address your concerns. Basically the app will only show the condition of your RDX when you last turned off the ignition. For example if all your tires were at perfect pressure when you turned off the ignition, and an hour later one of your tires was slashed with a knife, the app will continue to show perfect tire pressures. The link will also explain why you see the "false" warnings. The app actually works quite well if you can overlook the extremely annoying slow speed.
AcuraLink Is Crying Wolf
