What is the lifespan of remote key battery?
I have the RDX for almost a year and I think the remote key shows signs of a dead battery. Is it normal?
I had my Camry for 11 years and I used the same key all the time, no need to replace the battery.
I understand that RDX checks the chip more often, but only one year is a short life I reckon
Given that I've had batteries go bad in a half year and some that work for 5 or more years, having a spare around seems a bit overkill. By the time you need it, the "new" battery might be dead and they are available in most every drug store or grocery.
mrgold35
I've notice with the fob on all three vehicles seem to lose range over time. Even after replacing the battery, the range decrease seems to stay. I just replaced my Driver1 FOB on my MDX because it took up to 3 clicks to engage sometimes. It was replaced under warranty. I would double-check to see if the problems you are having is just one fob or both.
I would replace the OEM battery with a lithium cell... they last about 7-10 years... in older fobs... I would expect about half of that in a newer one
Many factors are in play here - length of time in use, how often it is used, temperature conditions and how "fresh" was the battery when it was installed. I think most of our cars use batteries that can easily be replaced at many stores so it is no big deal when they "die".
i just replace my 2015 rdx i havent had the car the whole time but assuming 2014 - 2017.5 3.5 years of normal daily use? and my car did give me a message letting me know it was running low
Battery life will ultimately depend on how much you use it.
You could set the option to allow all doors to be unlocked with a single press of the unlock button. This would avoid you having to press it twice to unlock the other doors. Use the buttons on the front doors to lock and use the unlock by just grabbing the handle - though still using some power from the keyfob, I'm sure the pressing a button on it uses more power comparatively.
MetalGearTypeS
08-29-2016 08:28 PM
soupi
14
11-15-2015 11:15 AM
