What is the lifespan of remote key battery?
Old 04-10-2014, 09:25 AM
drumultaberei's Avatar
I have the RDX for almost a year and I think the remote key shows signs of a dead battery. Is it normal?
I had my Camry for 11 years and I used the same key all the time, no need to replace the battery.
I understand that RDX checks the chip more often, but only one year is a short life I reckon
Old 04-11-2014, 11:44 AM
GRDX's Avatar
My dealer recommends replacing the battery yearly to avoid problems but mine have lasted 23 months so far. It all depend on how much you use them. The keyless fobs are tougher on the batteries than standard fobs.
Old 12-13-2014, 10:22 PM
TRD
6th Gear
TRD's Avatar
Does anyone know what size battery the non-nav RDX key fob uses?
It might be worth having a spare around.
Thanks in advance.
Old 12-14-2014, 04:43 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
The battery should last a year or so. At $3 for the battery it costs less than a penny a day. You're right, that is unacceptable.
Old 12-17-2014, 04:08 PM
Al Dente's Avatar
Not sure about non-nav, but on my 2013 Tech it's a CR 2032. It's easy enough to check by opening the fob.
Old 12-19-2014, 09:11 AM
ceb
ceb's Avatar
Thanks in advance.
Keyfob batteries generally give you advance notice of failure. First you'll notice a decrease in range when unlocking remotely. With fobless entry, you'll notice that it doesn't always work in your pocket - but works when you remove it and hold it in your hand.
Given that I've had batteries go bad in a half year and some that work for 5 or more years, having a spare around seems a bit overkill. By the time you need it, the "new" battery might be dead and they are available in most every drug store or grocery.
Old 12-19-2014, 09:15 AM
Lone Wolf
brian6speed's Avatar
Had mine since 2002 and still functions fine, no new battery needed yet.
Old 12-25-2014, 01:16 PM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
I've notice with the fob on all three vehicles seem to lose range over time. Even after replacing the battery, the range decrease seems to stay. I just replaced my Driver1 FOB on my MDX because it took up to 3 clicks to engage sometimes. It was replaced under warranty. I would double-check to see if the problems you are having is just one fob or both.
Old 01-26-2015, 03:57 AM
YeuEmMaiMai's Avatar
My cl type s is 14 years old and I have replaced the keyfob battery once on the primary remote during the time I have had the car.... I got the car when it was 3.5 years old. I have yet to change the one on the secondary. Acura used a lithium battery in those remotes...
I would replace the OEM battery with a lithium cell... they last about 7-10 years... in older fobs... I would expect about half of that in a newer one
Old 01-26-2015, 04:24 PM
RenoTL's Avatar
Many factors are in play here - length of time in use, how often it is used, temperature conditions and how "fresh" was the battery when it was installed. I think most of our cars use batteries that can easily be replaced at many stores so it is no big deal when they "die".
Old 11-12-2017, 06:53 PM
auskip07's Avatar
i just replace my 2015 rdx i havent had the car the whole time but assuming 2014 - 2017.5 3.5 years of normal daily use? and my car did give me a message letting me know it was running low
Old 11-18-2017, 11:45 AM
RDX2018's Avatar
Battery life will ultimately depend on how much you use it.
You could set the option to allow all doors to be unlocked with a single press of the unlock button. This would avoid you having to press it twice to unlock the other doors. Use the buttons on the front doors to lock and use the unlock by just grabbing the handle - though still using some power from the keyfob, I'm sure the pressing a button on it uses more power comparatively.
MetalGearTypeS
08-29-2016 08:28 PM
soupi
14
11-15-2015 11:15 AM
eastcoastguy
10-29-2015 03:00 PM
malvothegreat
09-29-2015 12:38 AM
Sue1910
2G CL Problems & Fixes
09-27-2015 12:34 PM
Quick Reply: What is the lifespan of remote key battery?
