Windshield rear view mirror
You're going to have to be more specific. There are multiple sensors, IR sensor for the automatic windshield wiper, or the camera for the lane assist/vehicle tracking. Or the sensor on the rear view mirror that dims the mirror when someon uses their brights behind you.
The reason I'm asking is I mounted a Dash Cam to my windshield in front of it without realizing there was a sensor it would be blocking. It doesn't seem to affect anything obvious, but would like to know if I have to re-located the dash cam.
Although the owners manual does not describe the purpose of this sensor, "I think" it is used to determine the amount of light coming into the windshield from the front of the vehicle. The amount of light coming in the rear windows is determined by the sensor on the front side of the mirror.
If it is dark in the front of the vehicle, and bright in the rear, then the system determines it is nighttime and another car is following, so the mirrors will dim to prevent blinding the driver.
I think if you block this sensor, so that it looks dark in the front, then the mirrors may dim during regular daytime driving (because the rear sensor sees lots of light) which will reduce the visibility in all your rear-view mirrors.
It really depends on how much light your new cameras is blocking.
EDIT: I just had a thought that if this is a light sensor, it may also be used to determine when your headlights turn on automatically. You might want to put some black tape over the sensor and see if you notice anything abnormal with the headlights or rear view mirrors.
charlie65 (04-15-2017)
You had a prismatic mirror - which worked better. My experience with the interior mirror is that the dimmer does almost nothing, whereas the outside mirrors work great.
Yup, the good old days. My comment "makes me wonder how we got along before" was with "tongue in cheek"
I would rather have the old style myself.....
Today was a sunny day, so I went for a short drive and placed my hand over the mirror sensor, and yes, both side mirrors and the rear view mirror dimmed. It took a few seconds to respond but the difference is quite noticeable.
Next time, I'm going to unplug the harness that feeds into the rear view mirror and for a night drive. To be continued........
