Notices
LED Factory Fog Lamp Upgrade
Old 07-04-2018, 01:08 PM
Registered Member
Anyone purchase the OEM LED Fog Lamp Upgrade for second gen RDX offered by most Acura Dealers? Is the lighting significantly improved?
In the past I've done DIY Fog Lamp upgrades with mixed results.
https://www.acurapartsforless.com/oe...ts-08v31tx62a0
DMorgens is offline
Old 07-15-2018, 08:39 PM
Registered Member
I would recommend the LED fog lights from theretrofitsource.com
https://www.theretrofitsource.com/ac...to-xb-led.html
Plug and play, and significantly cheaper than OEM. Light output is awesome.
misturnice is offline
wsw (03-12-2019)
Old 07-17-2018, 09:27 PM
Registered Member
ThaChadwick's Avatar
i have the OEM LED fogs and it does improve the lighting IMO. I also like the blue housing.
ThaChadwick is offline
Old 08-22-2018, 01:36 PM
Registered Member
So what will be advantages of OEM LED fogs vs Morimoto X? Are they worth premium price paid?
kether is offline
Old 08-23-2018, 10:01 PM
Registered Member
awoc's Avatar
I bought a $50 ebay kit, and I'm very happy with them.Light output is evenly spread. A lot better than the halogen oem. I hadn't seen the Morimoto kit prior to purchasing. The Morimoto looks like a nice kit.
awoc is offline
Old 08-31-2018, 12:04 PM
Registered Member
sathiyan's Avatar
Could you please share the ebay item link?
sathiyan is offline
Old 09-01-2018, 08:42 PM
Registered Member
https://www.ebay.com/itm/38255172775...m=382551727757
Just one of the options other than Morimoto.
kether is offline
Old 10-20-2018, 08:00 AM
New Member
I had it installed on my RDX Tech. It more for looks but it does had a little more light when driving.
Jfinley0 is offline
Old 03-12-2019, 07:44 PM
Registered RDX Member
brenakie's Avatar
Resurrecting this thread.. Looking to upgrade my OEM fog lights to LED on my 17. It's been a few months since the last post and you know how things change.... Any Amazon recommendations?
brenakie is offline
Old 03-13-2019, 04:56 PM
Registered Member
See the thread from Gadjetjq https://acurazine.com/forums/2g-rdx-...cement-952127/
I did it on both my 2017 RDXs and am very happy.
fcostantini is offline
brenakie (03-13-2019)
Old 03-18-2019, 07:59 AM
brenakie's Avatar
@fcostantini thanks for the info I appreciate it, @Gadjetjq post helped out a lot. I upgraded mine over the weekend, purchased a set from
Amazon Amazon
, upgrade took about 15 minutes.
Took a few pics of the install.
brenakie is offline
Old 03-18-2019, 11:40 AM
New Member
Headlight fix
Is it possible to replace the driver's side low beam on a 2000 tl without removing the front bumper?..........Frankie
FRANKIE111 is offline
Old 03-21-2019, 08:06 PM
Registered Member
Originally Posted by brenakie View Post
@fcostantini thanks for the info I appreciate it, @Gadjetjq post helped out a lot. I upgraded mine over the weekend, purchased a set from Amazon, upgrade took about 15 minutes.
yellow leds or film over fog lights?
I've been debating whether or not i wanted to go yellow or stick with white...
johnnyytruong is offline
Old 03-22-2019, 08:49 AM
brenakie's Avatar
johnnyytruong Yellow LEDs, happy with them. Purchased them @ Amazon (link in previous post).
brenakie is offline
Old 04-08-2019, 07:36 AM
JD8
Registered Member
JD8's Avatar
JD8 is offline
KB1Spec
3G MDX Discussion (2014+)
06-04-2015 04:34 PM
97AcuraCL
04-20-2012 03:53 PM
grrillaC
1G & 2G MDX Discussion (2001-2013)
06-09-2009 08:48 AM
CQ7String
08-21-2007 04:41 AM
GSGOMEZ
03-30-2005 12:20 AM
Quick Reply: LED Factory Fog Lamp Upgrade
