Driving light turn on with parking lights
7th Gear
I have a 2017 RDX Advanced, Tech Plus. I would like to modify the driving lights so they can be turned on with the parking lights. Has anyone done a modification like this? Also trying to find a service manual that covers this vehicle. Thanks in advance for your ideas or assistance.
The parking light signal is sent to drl lights, then the drl lights shut off. The grey plug in your headlights does this. Not exactly sure which color off the top of my head. You can just cut this wire that leads into the grey plug. Why exactly do you need this?
7th Gear
AWOC, Thanks for responding. My original post is referencing the driving (fog) lights located under the bumper. Not the Daylight Running Lights (DRL). If you have any information on the driving lights it would be appreciated. Thanks.
https://acurazine.com/forums/third-g...switch-772633/
Same concept, but the wire colors are probably different. Your fog light relay is inside the fuse box. You have to locate the relay, & figure out which wires are going in and out of it from the bottom of the fuse box.
