Crush (sealing) Washer Size for 2016 RDX AWD
I have not been able to find a complete listing of crush washers needed for my RDX.
I need sizes for:
Oil plug
Transmission Drain and Fill plugs
Rear Axle Drain and Fill plugs
Transfer Case Drain and Fill plugs
Last rear axle change I asked the dealer, he sold me 2, one was too large and both were about $3 each. If he wasn't 25 miles away I would have returned them.
Thanks for your help.
I need sizes for:
Oil plug
https://www.acuraoemparts.com/auto-parts/2016/acura/rdx-5-door/tech-awd-trim/6-speed-automatic-engine/chassis-cat/rear-differential-mount-scat
It takes some digging but any online Acura oem parts dealers should have a breakdown and part number for what you need.
Hud (07-14-2018)
If you are going to be doing all these fluid replacements yourself, I would suggest you go with magnetic drain plugs such as the Gold Plug. You can purchase a Gold Plug for each component and also get replacement washers at the same time.
Hud (07-14-2018)
My Home Planet
The oil drain plug was 20mm and the differential was 18mm. Those are the only ones I've change so far. Got both on amazon in a bag of 10 or so for $5-6 or close to that.
PixelHarmony
11-17-2010 03:02 PM
