Cargo area light improvement
Old 04-22-2013, 04:49 PM
etc25's Avatar
Has anyone done anything to improve the amount of light in the cargo area? Those 2 lights in the liftgate are a bit dim? Anyone replace those with LEDs or come up with a better solution?
Old 04-22-2013, 10:09 PM
dc5k20z1's Avatar
I replaced them with white LED bulbs but changed them back to oem. There was more light with the LED bulbs but not much. I was going to change all the interior bulbs to LED but changed my mind (personal preference) I only changed my license plate bulbs and reverse bulbs. I think the reason why not much light is back there is because of the angle when the tailgate is fully up.
Old 04-22-2013, 10:20 PM
etc25's Avatar
dc5k20z1 , thanks for the feedback. If we had a 12V socket back there I would add another light.
Old 04-23-2013, 12:06 AM
ipribadi's Avatar
I did mine!
I changed them to some el cheapo ebay LED lights.
They are noticeably brighter than OEM bulbs.
I observed the housing and the cavity is pretty large and the bulb is mounted sideways.
I then got a "ping pong bat" T10 194 style LED, kinda like these:
http://www.ebay.com/itm/181047355294
Or if you want to go with high quality LED's (5K white) I'm sure these are bright enough too:
http://www.vleds.com/5k-white-4-led-...58-1-pair.html
kirbman (05-13-2019)
Old 05-07-2013, 06:08 AM
TBC787's Avatar
Originally Posted by ipribadi
I did mine!
Are those just plug and play or was there another step involved in that installation?
Old 05-08-2013, 10:31 AM
ipribadi's Avatar
To me it was plug and play.
I was worried about polarity, but the ones I got turned out to be fine. I think most flank style LEDs are made to be non polarity specific.
The following 2 users liked this post by ipribadi:
carbonTSEX (01-10-2018), TBC787 (05-08-2013)
Old 08-26-2014, 02:13 PM
Schatten's Avatar
Tail gate interior lights
I can't find any info on replacement of these bulbs in the owner's manual. How do you access the bulbs? Just pop out the bulb cover?
Old 08-27-2014, 06:59 PM
Make it #7!
5 Acuras's Avatar
Would these work?
Amazon.com: Sylvania 168/194/2825 Premium White LEDriving Bulb: Automotive Amazon.com: Sylvania 168/194/2825 Premium White LEDriving Bulb: Automotive
Old 08-28-2014, 04:17 PM
Al Dente's Avatar
I'd also like to know how to take this out.
Old 01-21-2016, 04:06 PM
9th Gear
dmtchung's Avatar
I hooked up a 1.5 watt cob led bolt light. It's so bright. Let me know if you want to know the diy step by step
Old 01-21-2016, 04:47 PM
9th Gear
dmtchung's Avatar
All it takes is 1 light. Here's the
picture of where I mounted it on. And how bright it is
1.5 watt COB LED bolt light
that's where I install it. easy!!
Old 01-21-2016, 04:52 PM
9th Gear
dmtchung's Avatar
This is picture from 10 feet away. Notice where the light cut off is. Super bright
Old 01-22-2016, 10:48 AM
thephantom's Avatar
These are super bright: White LED 1X Trunk Cargo Light 12-SMD Panel Interior Light
Old 05-19-2017, 09:51 AM
kchoy's Avatar
dmtchung - do you have the picture of the light.
is it this one ?
https://www.amazon.ca/LED-light-SODIAL-1-5W-parking/dp/B00PGTLY82/ref=sr_1_fkmr2_3?ie=UTF8&qid=1495205139&sr=8-3-fkmr2&keywords=1.5+watt+cob+led+bolt+light https://www.amazon.ca/LED-light-SODIAL-1-5W-parking/dp/B00PGTLY82/ref=sr_1_fkmr2_3?ie=UTF8&qid=1495205139&sr=8-3-fkmr2&keywords=1.5+watt+cob+led+bolt+light
diy step by step if you can.
Old 09-13-2017, 08:31 PM
ThaChadwick's Avatar
I have now joined the club, replacing cargo, done, and door lights with Phillips LEDs
Old 11-18-2017, 11:18 AM
RDX2018's Avatar
Nice... think I'll shop around for these Philips LEDs and make this a project once the weather warms back up
Old 01-09-2018, 07:54 AM
9th Gear
dmtchung's Avatar
is it this one ? https://www.amazon.ca/LED-light-SODI...led+bolt+light
Yes...these lights from amazon work
1) Remove he dome light fuse in the engine bay. It's one of those tiny one. 1.5 am or something.
2) remove the plastic access panel back of the hatch ( this is the access panel to replace the license plate light )
3) You'll trace the wire that feeds the power to the trunk light. Tap it and use it to power your COB LED
4) drill a hole on the access panel, thread the bolt light thru
5) put dome light fuse back
That's it
02-25-2020 09:57 AM
lland
10-04-2015 04:47 PM
d.lim
09-15-2015 08:54 PM
Dunnik
09-14-2015 02:56 AM
EE4Life
09-11-2015 10:13 PM
Quick Reply: Cargo area light improvement
