2015 Acura RDX remote start install
Old 03-17-2019, 03:27 PM
davemikelong's Avatar
Hi All,
I'm currently trying to install an MPC remote start kit into my 2015 Acura RDX and I need to locate the "parking light switch connector" which it appears they are saying it either in the steering wheel or just behind the steering wheel in the dash. I located all of the other connections but can't seem to locate this last connection. Does anyone know where to locate this? Thank you in advance.
Best regards,
Michael
Old 03-17-2019, 04:20 PM
dave08902's Avatar
The connector is at the steering wheel combination switch and goes directly to the MICU fuse panel. Attached is the wiring diagram for the lighting control.
Hope this helps.
File Type: pdf
Old 03-18-2019, 09:40 AM
Hope this helps.
Thanks Dave. Do you happen to know in what general vicinity I'd physically locate that? I took the top off the steering wheel and I didn't see it there. It's not clear to me where that is in the fuse box area either. I'm thinking I can follow the brake sensor wires to it possibly?
Old 03-18-2019, 09:45 AM
dave08902's Avatar
The connector is located right at the turn signal module. You may need to remove the upper and lower covers to see it. The wiring diagram has the color of the wires. Match them up at the fuse box connectors.
Old 03-18-2019, 01:19 PM
dave08902's Avatar
On page two of the steering column removal shows "A"connectors. The one on the left is the turn signal combination switch connector.
evancamp13
2G RDX Performance Parts & Modifications
12-27-2018 12:54 PM
evancamp13
11-29-2018 10:31 AM
Dealgirl19
06-01-2015 11:05 AM
bigbwb
04-19-2015 08:05 PM
michalm
1/2G MDX (2001-2013)
02-12-2010 04:56 AM
Quick Reply: 2015 Acura RDX remote start install
