2013 Rear Brake Pads
General question on the rear brake pad replacement. I noticed that the rear brake pads have a 3 prong clip in the center of the back brake pad on the rear. It seems like this clip sears inside the caliper. Not sure if you install the pad on the caliper first? Just want to make sure it gets installed correctly.
The system has a lot of metal to metals contacts, so I put grease on the 3 prong clip, sides of the pads touching the pad spring, and the pad ears.
hope this helps.
Replacing my rear pads on 2015 RDX. With the flange bolts removed, the caliper body is stuck in place by the pad spring. How do I release the pad spring to lift the caliper body and replace the pads? Thanks!
summerayu
08-11-2012 08:42 AM
JeffTSX
22
09-16-2004 10:54 AM
