ELS--track order problem on USB memory stick
Hi all,
I have "Artist" folders on a memory stick. I recently bought an album from iTunes and converted it to MP3s and put them in a new folder. When the ELS displays and plays the tracks, they are all out of order and it adds a 2-digit number on front of each track ie: 01, 02, 04 12 etc.etc
I tried renaming all the tracks by adding a number in front of the filename in the correct order, just in case the ELS puts the tracks in alphabetical order. This did nothing, they were all still jumbled up on the ELS. I also tried adding a letter such as A, B, C etc at the beginning of the filename,,,,no luck.....i even removed all tags from the MP3's such as Track #...no luck. WTF?
Also, why is the text on this forum suddenly so small? i can barely see it and have never seen anything like it. Its a REAL PITA when correcting typos !!
Thanks, that helped. The key takeaway in that thread was that the system will play/display the tracks in the order that they were added to the folder. This did the trick. Unfortunately it meant that for this album, I had to copy the tracks to the USB folder one by one,. If you copy/move all tracks at once, you really have no control over which ones get added first, second, third etc etc. with regard to the timestamps on the "copy complete" operation.
NSXFTW
31
11-08-2018 10:27 AM
KrylonBlue
08-22-2012 12:58 AM
TheGoodGuy
09-07-2009 08:29 AM
ash3ktl
03-03-2006 09:35 AM
